Aggregate exports records into Fusion tables in which you have the option
to show meta fields such as meta-is-complete
These fields are not present in the XML files saved in the instances
directory, I believe they are actually written in the phone's database. Is
there a way to edit these?
Why? for example, to move a bunch of completed surveys onto a phone, and
then upload them to aggregate. Because they were not originally completed
on that phone, the "meta-is-complete" field is not set to True, so ODK does
not recognize them as completed surveys.
☞§※☼:airplane:
~Neil
The "meta-is-complete" is Aggregate's an aggregate state not a collect
state. Collect, Briefcase, or any other submitter can chunk the
submission when uploading so Aggregate only receives part of the
submission instead of all the data at once. Is complete represents
whether Aggregate has received the full submission data.
Waylon
On Thu, Nov 17, 2011 at 9:07 AM, Neil Hendrick wrote: > Aggregate exports records into Fusion tables in which you have the option to > show meta fields such as *meta-is-complete* > These fields are not present in the XML files saved in the instances > directory, I believe they are actually written in the phone's database. Is > there a way to edit these? > Why? for example, to move a bunch of completed surveys onto a phone, and > then upload them to aggregate. Because they were not originally completed on > that phone, the "meta-is-complete" field is not set to True, so ODK does not > recognize them as completed surveys. > ☞§※☼✈☂☻ > ~Neil >Thanks, W. What field is set by checking the "Mark form as Finished" field
at the end of a survey in ODK?
☞§※☼:airplane:
~Neil
On Thu, Nov 17, 2011 at 1:24 PM, W. Brunette wrote:n when uploading so Aggregate only receives part of the
mark form as finished is only used in the odk collect instance db.
it's not stored in the form or sent to the server.
