Missing exported data
Some of my exported data (Observation ) are missing. I have sent data to the ODK account in different times and the most recent once is not exported because when I download exported data I don't see these data.
Tablets and the server is lshtm server
Guide me please to the best way to see my data exported in the excel sheet and if there is any way to resend data from the tablet again to the server
I tried to export data from the server many times and check the data but still can't find these data
Hi @AbrarAlasmari
if your filled forms are still on your device (you don't use delete after send option and you didn't remove them manually) you can go to Send Finalized Forms -> Three Dots icon -> Change View -> Show Sent and Unsent Forms and you can send your forms again.
Thank you- I don't see these options when I go to Send Finalized Form, it is empty.
I have not deleted any form nor data from the tablet, Is there any other way to re-send these data.
Also what if i faced the same issue after re-sending? How can I solve this issue of missing exported data .
Thanks again for your help
Abrar
How is it possible you can't see them?
Got it :slight_smile: thanks
I will try to re-send now and see if it works
Abrar
I still have the same issue even after re-sending data .
There are missing exported data that have been sent to the server but I can't see these in the exported file .
Would appreciate if anyone could help
Abrar
Ok, I have a few questions:
  1. What do you use as a server? Google Sheets?
  2. Which ODK Collect version do you use?
  3. What can you see in the dialog after sending your forms? Is there SUCCESS after each instance name?
It's possible the submissions are being marked as incomplete as @Jefferson_Francisco experienced in Form status - #8 by Jefferson_Francisco. Do you see them on the server in "Form Management" > "Submission Admin"?
How many submissions are missing in your export?
Excel sheet
Version 1.0
Yes success when I first sent these but when I tried to re-send these I got some errors
Than you- Yes I can see two incomplete what should I do with these
Not all missing data are shown as incomplete
You can see whether or not they are missing any media and mark them as complete to make them part of your dataset.
How many others are missing? Are they ones you have resent?
Thanks a lot- Now it's just one missing..
I have already sent that one missing
Thanks a lot for your help very useful
Abrar
