I'm trying to build a form that has an extensive area of instruction prior
to the survey questions, my issue is that I would like to present the
instructions as a mixed grid, see below for explanation:
Column 1 Column 2 Column 3
Row 1 image note image
Row 2 image note image
Has anyone been able to present onto a tablet size (7") screen anything
similar to this layout. I'm building forms using XLSForm but happy to
modify the XML directly.
Once again many thanks for any help the Community may offer
Layout changes like this require a Java code change.
The newer ODK 2.0 tools will enable anyone with HTML/Javascript skills to
define alternate layouts such as this.
On Tue, Dec 10, 2013 at 1:40 AM, Mick T wrote:
Hi All,
