I was just wondering if it is possible to monitor which Data Viewers login to the ODK Aggregate server and when they do so. As part of quality assurance, our research supervisors are supposed to login to the Aggregate server to view data and check quality. However, we would like to be able to monitor this activity to make sure that they are actually doing this. Is there a way that we can check on this, possibly through the App Engine logs?
We are using the ODK Aggregate built on the Google App Engine
