Weijia,
Fusion Tables doesn't work like that. Have you tried it out?
On Mon, Apr 7, 2014 at 4:20 AM, Weijia Chen chenwjkingoflion@gmail.com wrote:
Hi Yaw,
If a new report is generated and send to my website, can I get an alert that
tells me I get a new report?
Weijia
On 26 March 2014 17:36, Yaw Anokwa yanokwa@nafundi.com wrote:
Weijia,
Stream the data from ODK Aggregate to Fusion Tables. From there, you
can build custom
views of the data.
On Wed, Mar 26, 2014 at 6:59 AM, Weijia Chen chenwjkingoflion@gmail.com wrote:
Hi Yaw,
Thanks for your reply.
How can I do the following two things?
I do not want anonymous users to visit all the met data, I just want
them
to visit the calculate section and only visualise the geopoint on the
map to
anonymous users.
How can I let reporters to see their contributions? For example: how
many they report and when they report? Meanwhile, apart their own data,
other data they only can see the calculate data as well like the
anonymous
users and only visualise the geopoint on the map as well.
Best Regards,
Weijia
On 25 March 2014 13:53, Yaw Anokwa yanokwa@nafundi.com wrote:
Weijia,
If you want GPX tracks attached to a form, you'll have to write code
(in Collect, XLSForm, Aggregate, etc) to support that.
If you want to collect a trace inside the form, there is ongoing work
by the community to add that functionality (see
https://groups.google.com/forum/#!topic/opendatakit-developers/AfVgKcpE6Jk).
There is no ETA on this feature.
On Tue, Mar 25, 2014 at 5:00 AM, Weijia Chen chenwjkingoflion@gmail.com wrote:
Hi Yaw,
Can the XLSform designed to track GPS from A to B?
Weijia
On 23 March 2014 15:57, Yaw Anokwa yanokwa@nafundi.com wrote:
Weijia,
Don't know, but depends on the GPS. Perhaps you can try it out on
your device and report back to the community.
Not unless you write code to do this.
On Sun, Mar 23, 2014 at 8:26 AM, Weijia Chen chenwjkingoflion@gmail.com wrote:
Yaw,
If a user in the car and during the congestions, vehicle speed
does
not
very fast, what the performance of GPS at that situation?
Can user share their report through their social media account?
Best Regards,
Weijia
On 22 March 2014 20:28, Yaw Anokwa yanokwa@nafundi.com wrote:
Weijia,
GPS acquisition depends on if you have a clear view of the sky
and
how
much distance you moved from your previous location.
ODK Collect does not have support for getting location in the
background. It's something that's been discussed before, but it's
never been built.
server
On Sat, Mar 22, 2014 at 9:15 AM, Weijia Chen chenwjkingoflion@gmail.com wrote:
Hi Yaw,
Thanks for your comments and suggestions. Another question,
I set geopoint accurate should be less than 5 meters. I found
that
it
does
not perform very well when recording the geopoint every time,
not
just
the
first time. I also found that around different indoors, the
geopoint
performs different as well. Some where, it could get the
location
very
fast,
but other place, it could not get the data.
Can I set geopoint as the default metadata when loading the
form?
Weather it
could run at the backstage automatically?
I'm looking forward to your reply.
Best Regards,
Weijia
On 21 March 2014 21:14, Yaw Anokwa yanokwa@nafundi.com wrote:
Weijia,
There's no easy way to get road name based on a geopoint.
If there are very small number of geopoints and you are using
Collect
1.4.3 I could imagine a form that converts a geopoint to a
string
and
then uses that as a lookup in an external itemset where you've
put
the
geopoint to road links.
I've never tried this, can't spend time trying it, and I'm
pretty
sure
it's a bad idea. But, it's your best shot if you don't want to
customize ODK Collect with Java code.
server
On Fri, Mar 21, 2014 at 11:49 AM, Weijia Chen chenwjkingoflion@gmail.com wrote:
Hi Yaw,
I have solved the problem of create the sentence. ODK is
very
powerful.
I have another question:
Can ODK retrieve road name based on collected geopoint?
I'll be grateful with your help and looking forward to your
reply.
Wish you and your family have a nice weekend.
Best Regards,
Weijia
On 20 March 2014 20:31, Yaw Anokwa yanokwa@nafundi.com wrote:
Weijia,
Yes. And if you want to show it to the user, look into
using
output
tags.
server
ODK.
On Thu, Mar 20, 2014 at 1:26 PM, Weijia Chen chenwjkingoflion@gmail.com wrote:
Hi Yaw,
Fabulous! After binding to a sentence, the raw data of
each
selection
would
be still showed on the web server, isn't it?
Weijia
On 20 March 2014 20:08, Yaw Anokwa yanokwa@nafundi.com wrote:
Weijia,
Yes, you can use calculate, concat, and jr:choice-name
to
build
sentences. See
http://opendatakit.org/help/form-design/binding
for
their usage.
design,
server
for
ODK.
On Thu, Mar 20, 2014 at 12:13 PM, Weijia Chen chenwjkingoflion@gmail.com wrote:
Hi Yaw,
Thanks for your reply and help.
By the end of the report generation from the
Smartphone
app,
can a
sentence could be generated based on each selection?
For
example:
first
step: traffic congestion, second step: northeast,
third
step:
stand
still
(congestion level), forth step: car fire (congestion
reason),
fifth
step: A
1 (road), sixth step: 10 mins (waiting time). Then a
sentence
like
this
could be generated before submit to the web server,
"traffic
congestion
northeast stand still caused by car fire at A1 waiting
10
mins".
If Smartphone app could not do this, after a report
is
submitted
to
web server, can web server do this? Combine each lab
to a
sentence?
I'm looking forward to your reply. I'll be grateful
with
your
help.
Best Regards,
Weijia
On 13 March 2014 21:18, Yaw Anokwa yanokwa@nafundi.com wrote:
Hello Weijia,
Welcome to the ODK community.
You can add deviceID and userID to your form. If
you
are
using
XLSForm, see the metadata section on
http://opendatakit.org/help/form-design/xlsform/ for
a
how
to.
Then
when you download your data or build your reports,
you
can
order
by
deviceID or userID to see the counts.
If by your website, you mean ODK Aggregate, then
no,
not
without
writing some custom code. If this is an important
feature,
you
can
file a feature request at
https://code.google.com/p/opendatakit/issues/list or
hire a
deveopr
from http://opendatakit.org/help/help-for-hire/.
design,
server
for
ODK.
On Thu, Mar 13, 2014 at 9:42 AM, Weijia Chen chenwjkingoflion@gmail.com wrote:
Hi there,
I'm a new users of ODK and I have two new questions
about
ODK.
Can I monitor how many reports of per device or
per
person?
Can I use the Google analytics to monitor the
number
of
visits
of
my
website?
I'll be grateful with any help of the Community and
appreciate
the
time that
you spent.
Cheers,
Weijia
Unsubscribe:
opendatakit+unsubscribe@googlegroups.com
Options:
http://groups.google.com/group/opendatakit?hl=en
You received this message because you are
subscribed
to
the
Google
Groups
To unsubscribe from this group and stop receiving
emails
from
it,
send an
For more options, visit
https://groups.google.com/d/optout.
Options:
You received this message because you are subscribed
to
the
Google
Groups "ODK Community" group.
emails
from
it,
send
Options:
to
the
Google
emails
from
it,
send
Options:
You received this message because you are subscribed to
the
Google
Groups
To unsubscribe from this group and stop receiving emails
from
it,
send
an
the
Google
Groups
from
it,
send
an
You received this message because you are subscribed to the
Google
Groups
from
it,
send
an
Google
Groups
from
it,
send
an
Google
Groups
To unsubscribe from this group and stop receiving emails from
it,
send
an
Google
Groups
it,
send
an
Google
Groups
send
an
Groups
send
an
Groups
send
an
Groups
send
an
Groups
an
Groups
an
Hi Yaw,
I tried Fusion Tables. But why I can just publish the fusion tables with
only one email address and why Fusion Tables can be shared with many email
addresses?
Moreover, expect the Fusion Table, do the ODK aggregate website can alert
administrator?
Weijia
On 7 April 2014 14:37, Yaw Anokwa wrote:
Weijia,
Hi Yaw,
that
Weijia
Weijia,
can build custom
views of the data.
On Wed, Mar 26, 2014 at 6:59 AM, Weijia Chen < chenwjkingoflion@gmail.com> wrote:
Hi Yaw,
want
them
map to
anonymous users.
how
data,
anonymous
Best Regards,
Weijia
Weijia,
Hi Yaw,
Weijia
Weijia,
on
server
Yaw,
speed
does
not
account?
Best Regards,
Weijia
Weijia,
and
how
it's
never been built.
server
Hi Yaw,
that
it
does
not
just
the
geopoint
location
very
fast,
form?
Weather it
Best Regards,
Weijia
Weijia,
using
Collect
string
and
you've
put
the
pretty
sure
to
server
ODK.
Hi Yaw,
very
powerful.
your
reply.
Best Regards,
Weijia
Weijia,
using
output
tags.
design,
server
ODK.
Hi Yaw,
each
selection
would
Weijia
On 20 March 2014 20:08, Yaw Anokwa < yanokwa@nafundi.com> wrote:
Weijia,
to
build
sentences. See
for
their usage.
design,
server
for
ODK.
Hi Yaw,
Smartphone
app,
can a
For
example:
first
third
step:
stand
still
reason),
fifth
step: A
sentence
like
this
"traffic
congestion
waiting
10
mins".
report
is
submitted
to
to a
sentence?
with
your
help.
Best Regards,
Weijia
Hello Weijia,
you
are
using
http://opendatakit.org/help/form-design/xlsform/for
a
how
to.
Then
you
can
order
by
no,
not
without
feature,
you
can
https://code.google.com/p/opendatakit/issues/listor
hire a
deveopr
form
design,
server
development
for
ODK.
Hi there,
questions
about
ODK.
or
per
person?
number
of
visits
of
my
website?
and
appreciate
the
time that
you spent.
Cheers,
Weijia
Unsubscribe:
Options:
subscribed
to
the
Google
Groups
emails
from
it,
send an
email to
Unsubscribe:
Options:
subscribed
to
the
Google
emails
from
it,
send
an email to
Unsubscribe:
Options:
to
the
Google
emails
from
it,
send
an email to
Options:
to
the
Google
Groups
emails
from
it,
send
an
Options:
the
Google
Groups
emails
from
it,
send
an
Options:
the
Google
Groups
from
it,
send
an
the
Google
Groups
from
it,
send
an
Google
Groups
from
it,
send
an
Google
Groups
it,
send
an
Google
Groups
it,
send
an
Google
Groups
it,
send
an
Groups
send
an
Groups
send
an
Groups
send
an
Groups
an
Groups
an
Weijia,
Not sure I understand your question. You can publish to Fusion Tables
from Aggregate using one Gmail account and share that table with
whomever (e.g., like all other Google Docs apps).
There is no alerting in Aggregate, but there's nothing stopping you
from building that functionality.
On Mon, Apr 7, 2014 at 6:52 AM, Weijia Chen chenwjkingoflion@gmail.com wrote:
Hi Yaw,
addresses?
administrator?
Weijia
On 7 April 2014 14:37, Yaw Anokwa yanokwa@nafundi.com wrote:
Weijia,
Hi Yaw,
that
Weijia
Weijia,
can build custom
views of the data.
Hi Yaw,
want
them
map to
anonymous users.
how
data,
anonymous
Best Regards,
Weijia
Weijia,
work
Hi Yaw,
Weijia
Weijia,
on
server
Yaw,
speed
does
not
account?
Best Regards,
Weijia
Weijia,
and
how
it's
never been built.
server
Hi Yaw,
found
that
it
does
time,
not
just
the
geopoint
location
very
fast,
form?
Weather it
Best Regards,
Weijia
Weijia,
using
Collect
string
and
you've
put
the
pretty
sure
to
server
ODK.
Hi Yaw,
very
powerful.
your
reply.
Best Regards,
Weijia
Weijia,
using
output
tags.
design,
server
for
ODK.
Hi Yaw,
each
selection
would
Weijia
Weijia,
jr:choice-name
to
build
sentences. See
for
their usage.
design,
server
for
ODK.
Hi Yaw,
Smartphone
app,
can a
selection?
For
example:
first
third
step:
stand
still
(congestion
reason),
fifth
step: A
a
sentence
like
this
"traffic
congestion
waiting
10
mins".
report
is
submitted
to
lab
to a
sentence?
with
your
help.
Best Regards,
Weijia
Hello Weijia,
If
you
are
using
for
a
how
to.
Then
you
can
order
by
then
no,
not
without
feature,
you
can
or
hire a
deveopr
form
design,
server
development
for
ODK.
Hi there,
questions
about
ODK.
or
per
person?
number
of
visits
of
my
website?
and
appreciate
the
time that
you spent.
Cheers,
Weijia
Unsubscribe:
Options:
subscribed
to
the
Google
Groups
receiving
emails
from
it,
send an
email to
Unsubscribe:
Options:
subscribed
to
the
Google
emails
from
it,
send
an email to
Unsubscribe:
Options:
subscribed
to
the
Google
emails
from
it,
send
an email to
Options:
to
the
Google
Groups
emails
from
it,
send
an
Options:
to
the
Google
Groups
emails
from
it,
send
an
Options:
the
Google
Groups
from
it,
send
an
the
Google
Groups
from
it,
send
an
Google
Groups
from
it,
send
an
Google
Groups
from
it,
send
an
Google
Groups
it,
send
an
Google
Groups
it,
send
an
Google
Groups
send
an
Groups
send
an
Groups
send
an
Groups
send
an
Groups
an
Groups
an
