I need help to know how to use Geo Location Monitoring system?
Thank you,
Naseem
Thank you,
Naseem
I don't know what that you mean. Can you explain like I'm five (ELI5)?
GLM is an output-monitoring tool in which a Global Positioning System (GPS) enabled
mobile phones are used to record and transmit the data gathered through interviews and
observations to a dedicated server. GLM falls under the information and Communication
Technology (ICT) based monitoring methods. Unlike the conventional output monitoring
GLM produces and presents the evidences of the physical outputs of a project showing
their exact geo-location and the changes unfolding over the time.
ODK Collect let's you collect GPS coordinates as part of the form. You can see what this looks like at https://docs.opendatakit.org/form-question-types/#geopoint-widget. Is that what you had in mind?
