For example, if I have 4 questions in my form. If I am not answered those 4 questions the required message must be shown simultaneously on the screen.
If you have any suggestion or any blog suggest me.
I have no idea. I just tried to find the solution in getodk.org and search for the solution in websites.
Hi danjoseph,
I just referred to the document but there is no option available to me.
Then I am trying to do If I unanswered 3 questions it will show the required message one by one. If I answer the first one and Then if I Click the next it will show the next error instead of that I need it at the same time simultaneously.
