I realize now that this issue is probably related to the database, and in
order to support a variety of databases without manipulating data, it would
makes sense to set NaN to empty in the client (like I presume ODK Collect
does). Unless others object, I'll do this in Enketo. (track: https://github.com/MartijnR/enketo-core/issues/40)
On Monday, July 21, 2014 11:29:41 AM UTC-6, Martijn van de Rijdt wrote:
> Aggregate submissions fail (with a 500 Unexpected Exception) when a
> submission for a calculated item multiplying 2 integers has the value NaN.
> See this thread:
> https://groups.google.com/forum/#!topic/opendatakit/UBIyAJNL8Z4
> NaN is a valid and useful value for Number types in XPath 1.0, so I wonder
> if this should be accepted for any integer or decimal datatype.
> What do you think?
> See this thread:
> What do you think?
On the Aggregate side, it is an issue with Java BigDecimal not accepting
"NaN" or "+/-Infinity"
I'm rather surprised that BigDecimal doesn't natively handle NaN or
Infinity.
BigDecimal is used for decimal values within ODK Aggregate.
Long is used for integer values within ODK Aggregate.
PostgreSQL: decimal values stored as DECIMAL(,) ; integer values are
stored as BIGINT() or INTEGER()
MySQL: decimal values stored as DECIMAL(,) ; integer values stored as
GAE: decimal values stored as numeric fields (Doubles); integer values
stored as long fields.
MySQL and PostgreSQL DBAs can tweak the precisions of what are stored in
the DB, and, after a reboot, ODK Aggregate will honor those changes.
See this thread: https://groups.google.com/forum/#!topic/opendatakit/
UBIyAJNL8Z4
wonder if this should be accepted for any integer or decimal datatype.
This is a bug and/or non-conformance of ODK Aggregate.
On Tue, Jul 22, 2014 at 10:33 AM, Martijn van de Rijdt wrote:
sorry forgot attachment
UBIyAJNL8Z4
So ODK Collect also quietly sets Infinity and -Infinity to empty?
> http://stackoverflow.com/questions/10080084/how-to-convert-double-positive-infinity-to-bigdecimal
> Infinity.
> On Mon, Jul 21, 2014 at 11:15 AM, Martijn van de Rijdt <mar...@enketo.org > wrote:
>>> UBIyAJNL8Z4
>>> What do you think?
>> "ODK Developers" group.
>> email to opendatakit-developers+unsubscribe@googlegroups.com
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
If not accepting NaN is also considered a bug (in addition to Infinity and
-Infinity), I'll reverse a workaround I made in Enketo for NaN in decimal
fields.
On Tue, Jul 22, 2014 at 10:33 AM, Martijn van de Rijdt <martijn@enketo.org wrote:
UBIyAJNL8Z4
What do you think?
Just tested. Infinite and -Infinite values for a node with the decimal type
cause the 500 error when submitting to Aggregate from ODK Collect. Not sure
where to file this bug (Collect, Aggregate or JavaRosa). See attached test
form.
Would be curious how you'd want to resolve this. I'm a bit reluctant to
overwrite NaN, Infinity and -Infinity completely in the XPath library. I'm
afraid it will have unintended consequences.
To reproduce:
upload form to latest Aggregate
load the form in ODK Collect
submit
Expected: Successful submission
Seen in ODK Collect: Error: Internal Server Error (500)
Cheers,
Martijn
On Tuesday, July 22, 2014 11:02:30 AM UTC-6, Martijn van de Rijdt wrote:
> Interesting. Thanks.
>> Infinity.
>> On Mon, Jul 21, 2014 at 11:15 AM, Martijn van de Rijdt >
>>> in order to support a variety of databases without manipulating data, it
>>> would makes sense to set NaN to empty in the client (like I presume ODK
>>> Collect does). Unless others object, I'll do this in Enketo. (track:
>>>> UBIyAJNL8Z4
>>>> What do you think?
>>> Groups "ODK Developers" group.
>>> an email to opendatakit-developers+unsubscribe@googlegroups.com.
>> Mitch Sundt
>> Software Engineer
>> mitche...@gmail.com
