Need advise on how to design form layout for use with ODK Collect Android App
I want to capture the below image data in the ODK Collect Android app. How best can I design my XLSForm
I am inclined to have 2 questions for each item, 1 question for the [5% Stufen] and another question for the Teilpr. (MZB). Is this the best approach?
Hi @Ronald_Munjoma ,
I don't know if it's the best but I'll do something like that.
Both questions on the same screen and the Item as title.
An alternate design might be: All first questions (5% steps) on one screen, and the relevant ones for the second question on the next screen. Separated for minerals and organic, or even together.
This might make it easier for the user to visibly control a 100% limit.
Furthermore, there might be two design options for the elements: matrix--style selects, repeat group with fixed repeat_count or separate groups.
As the number steps are fixed (5%), a select_one (e.g. minimal apperance) or range type might be an option.
The design decision should esp. address userfriendliness and easy analysis.
