I need help to create a skip logic that let a group of question appears only after a date (called base_date) is entered
Date and questions are in the same form (and question are all in the same Group).
I tried two different ways (in the design tool) to set the control of the skip logic:
base_date != ""
(after creating a calculate item "cross_base_date" related to base_date) cross_base_date was answered
but neither worked
I already use cross rules to check date between different forms, with no problem: I can't understand what Im doing wrong
thank you
