Why when I open my server I find this message?
AppEngine Application Problem
A problem has occurred that prevents your App Engine application from responding. Your application may have exceeded its per-minute or daily usage quotas.
Please visit Google Cloud Platform - App Engine Dashboard and select your application id from the top-right drop-down. The Billing Status section for your application id is displayed beneath the Summary and Instances sections.
Verify that you have not exceeded your free quota or daily spending limit (if you have set up billing) and that you have also not exceeded your per-minute usage limits.
If your application's usage limits have not been exceeded, then go to Google Cloud Platform - Overview Dashboard and confirm that there are no Google infrastructure issues (these will appear in the Google Cloud status box in the top-right of this page.
If neither of those indicate any problems, then your application's Logs may identify an issue. See ODK Aggregate Troubleshooting for what to look for.
What happened when you followed the instructions in the email you sent?
You received this message because you are subscribed to the Google Groups "ODK Developers" group.
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit-developers+unsubscribe@googlegroups.com.
