Hi iIm completely new to ODK I've been reading up on Odk for a bit now and i understand the part on how its used to make forms and transfer the data through different mediums.A friend of mine uses ODK for his work(don't know exactly what,he wont tell me) .He just said make a mobile app using ODK.I wanna know if u can really make an app using ODK.(apps that require programming language)If not then he must have meant making a form/survey that works like an app.If the latter is the case then can u give me link to a good step by step "app"(app that do not need programming language) making tutorial.And if u can make an app(programming language) using ODK will i need extensive programming knowledge or a basic understanding would suffice?
Your response and help Will be greatly appreciated thank you in Advance.
See our user documentation at http://opendatakit.org/
The training guides contributed by users of the tools may be helpful:
https://opendatakit.org/help/training-guides/
Advance.
