I have installed ODK Aggregate server on Virtualbox machine with a private
address, behind the router.
i'm able to access ODK web server link from my inside network without any
problems. I configured port forwarding on my router on port 80 and
forwarded traffic to my Virtualbox ODK machine. When i try to telnet from
internet to my public ip on port 80 it is sucessfull, but unfortunately i'm
not able to open the web link. For the first time web page is trying to
load but then tries to redirect on local ip (Virtul box) and then it
fails.Could you help me to resolve this problem?
When running the ODK Aggregate installer to build the WAR file for the
MySQL or PostgreSQL install, you should specify the public IP address and
public port you will be using to reach the server.
In this case, you should specify the IP address of your router and the port
on the router that you have configured to forward to your server.
If you then try to access the server from a computer on your local network,
the URL will be changed (redirected) to that router IP address and port.
This is necessary when using SSL certificates and is also used when
generating content with links to media files.
On Sat, Sep 5, 2015 at 4:57 AM, Levan Makharadze < levanmakharadze208@gmail.com> wrote:
Hi all
Thank you very much Mitch, i specified public ip during ODK installation
and port forwarding works fine. Thanks again for your help!!!
> port on the router that you have configured to forward to your server.
> network, the URL will be changed (redirected) to that router IP address and
> port. This is necessary when using SSL certificates and is also used when
> On Sat, Sep 5, 2015 at 4:57 AM, Levan Makharadze <levanmakh...@gmail.com > wrote:
>> Hi all
>> private address, behind the router.
>> Thanks in advance
>> "ODK Developers" group.
>> email to opendatakit-developers+unsubscribe@googlegroups.com
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
