Once the xml form is ready to fill on the mobile device, the questions
containing the alphabets æøåØÆÅ are transferred to question marks,
like this:
The actual question: Føler meg glad
This is how it is displayed on mobile screen using odk collect: F?ler
meg glad
Thanking you for all suggestions and they will be highly appreciated.
-selvmordsforskning
hi selvmord,
sorry things aren't working for you. can put the contents of the form
at dpaste.com and send out a link?
yaw
On Thu, Oct 28, 2010 at 06:02, selvmord forskning wrote:
> Hi,
> like this:
> meg glad
> -selvmordsforskning
I have solved this by using hex-values of these alphabets, like this:
Føler meg glad
which returns:
Føler meg glad
-Selvmordsforskning
On Oct 28, 3:30 pm, Yaw Anokwa wrote:
> hi selvmord,
> yaw
> > Hi,
> > like this:
> > meg glad
> > -selvmordsforskning
i suspect your original form was not in the utf-8 encoding
On Fri, Oct 29, 2010 at 3:11 AM, selvmord forskning < selvmordsforskning@gmail.com> wrote:
Føler meg glad
which returns:
Føler meg glad
-Selvmordsforskning
On Oct 28, 3:30 pm, Yaw Anokwa yano...@gmail.com wrote:
hi selvmord,
yaw
On Thu, Oct 28, 2010 at 06:02, selvmord forskning selvmordsforskn...@gmail.com wrote:
like this:
meg glad
-selvmordsforskning
Unsubscribe: opendatakit+unsubscribe@googlegroups.comopendatakit%2Bunsubscribe@googlegroups.com
agreed. if you are on windows, use notepad++ and make sure your
encoding is correct. if you are on a mac, textmate or textwrangler
should work.
> On Fri, Oct 29, 2010 at 3:11 AM, selvmord forskning wrote:
>> Hi,
>> Føler meg glad
>> which returns:
>> Føler meg glad
>> -Selvmordsforskning
>> > hi selvmord,
>> > yaw
>> > > Hi,
>> > > like this:
>> > > meg glad
>> > > -selvmordsforskning
