I am trying to use two features but not succeeding in any. First, i am trying to pass a select_one field's value as a part of the intent string eg. select_one farmer_mobile_number -> farmer_mobile_number and using this farmer_mobile_number i am passing it in the ex:android.intent.action.DIAL(uri_data='tel:${farmer_mobile_number}') but it is dialing some random arbitary values in the dialer.
Secondly, i am also using a select_one datatype to select the lat,long of a place, and want to redirect it to google maps, using url appearnace, but there also it is not concatinating with the field. eg. select_one farm_location -> farm_location, i am using this value of farm_location in the url's default like, concat('https://maps.google.com?q=',${farm_location}), still it is not getting appended. I have tried both join as well as concat, but nothing seems to help.
As, i mentioned you can set a select_one field and try to use that field's value in your intent's appearance, similarly for url also you can try to concat the field's value with the link you want to get redirected.
I tried using different approaches like using calculate datatype, and reading the value from it, and all but nothing seems to work.
