Dear all,
I have made a form with a not(selected) statement in the relevance field
with a reference to a label. I also set my default language to Spanish (in
the excel settings-tab). It seems that the not(selected) statement is not
working anymore with the spanish language. If I switch back to Default or
English, the not(selected) statement is working again. On the other hand,
the Select-functions always seem to work, even when I switch between
languages. So it seems that the not(selected) statement is sensitive to the
language of the label. Has anyone experience with this and how can this be
solved?
Thanks! Kind regards, Eddy
to work properly I use the name value, this in any language remains the
same.
El jueves, 19 de junio de 2014 02:18:54 UTC-6, Eddy Rellum escribió:
> Dear all,
> solved?
Hi Gabriel,
I did this, but it doesn't seem to work either... Only when I switch back
to English or Default Language. Very strange.
Regards,
Eddy
> same.
>> Dear all,
>> solved?
I have attached a file with a loop-repeat function and a not(select)
funtion. The no(select) function only works in English and Default
language. I can change the selection to the spanish labels, but this would
again cause problems for the English version. What can be the problem? I
didn't experience this problem before. Thanks for the feedback.
Kind regards,
Eddy
Loop_with_not_selected.xls (37.5 KB)
On Thursday, June 19, 2014 10:43:29 AM UTC+2, Eddy Rellum wrote:
> Hi Gabriel,
> Regards,
> Eddy
>> same.
>>> Dear all,
>>> solved?
I solved the problem this way:
yo solucionaría el problema de esta manera:
not(selected(${crops_energ_soilprep_id}, 'horse') or
selected(${crops_energ_soilprep_id}, 'by hand') or
selected(${crops_energ_soilprep_id}, 'donkey'))
Utilizando "crops_energ_soilprep_id" ya que estos no cambian, no importa
el idioma que usted escoja.
as these do not change, no matter what language you choose.
> Kind regards,
> Eddy
>> Hi Gabriel,
>> Regards,
>> Eddy
>>> same.
>>>> Dear all,
>>>> field with a reference to a label. I also set my default language to
>>>> Spanish (in the excel settings-tab). It seems that the not(selected)
>>>> statement is not working anymore with the spanish language. If I switch
>>>> back to Default or English, the not(selected) statement is working again.
>>>> On the other hand, the Select-functions always seem to work, even when I
>>>> switch between languages. So it seems that the not(selected) statement is
>>>> sensitive to the language of the label. Has anyone experience with this and
>>>> how can this be solved?
Thanks for helping, but your sollution does not work. I gives an error. I
see the problem: In the loop-repeat, I am forcing the form to use only one
value at the time, while setting this value to a string. On this moment,
the value becomes language dependant. So I need to find a way how I can
reset the selected value to a language independant value (as you said, by
using the 'name' column). I can't figure out how I can do this.
Thanks for the help! Very much appreciated!
>> Kind regards,
>> Eddy
>>> Hi Gabriel,
>>> back to English or Default Language. Very strange.
>>> Regards,
>>> Eddy
>>>> same.
>>>>> Dear all,
The formula in row 10 should use ${crops_energ_soilprep_id} instead of
${crops_energ_soilprep_name}.
The former is the non-localized choice name, the later is the in-use
locallized name.
Kind regards,
Eddy
Hi Gabriel,
Regards,
Eddy
the same.
Dear all,
Thanks Mitch, but I tried this and XLSForms gives me an error which I do
not entirely understand (somthing with String, se below). I guess it has to
do with the fact that 'calculate' in row 10 results in a number, not in a
string (?). When I try to select the value in ${crops_energ_soilprep_id} I
get an error from the XLSForm like stated below:
Error: ODK Validate Errors: org.javarosa.core.log.WrappedException: Error
evaluating field 'test': java.lang.Double cannot be cast to
java.lang.String => java.lang.ClassCastException[java.lang.Double cannot be
cast to java.lang.String]
Kind regards,
> locallized name.
>>> importa el idioma que usted escoja.
>>>> Kind regards,
>>>> Eddy
>>>>> Hi Gabriel,
>>>>> Regards,
>>>>> Eddy
>>>>>> the same.
>>>>>>> Dear all,
>> "ODK Community" group.
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
Try casting to a string with string(/path/to/node).
On Fri, Jun 20, 2014 at 11:51 AM, Eddy Rellum 4estsense@gmail.com wrote:
Thanks Mitch, but I tried this and XLSForms gives me an error which I do not
entirely understand (somthing with String, se below). I guess it has to do
evaluating field 'test': java.lang.Double cannot be cast to java.lang.String
=> java.lang.ClassCastException[java.lang.Double cannot be cast to
java.lang.String]
Kind regards,
locallized name.
value at the time, while setting this value to a string. On this moment, the
value becomes language dependant. So I need to find a way how I can reset
the selected value to a language independant value (as you said, by using
funtion. The no(select) function only works in English and Default language.
I can change the selection to the spanish labels, but this would again cause
problems for the English version. What can be the problem? I didn't
Kind regards,
Eddy
Hi Gabriel,
Regards,
Eddy
the same.
Dear all,
field with a reference to a label. I also set my default language to Spanish
(in the excel settings-tab). It seems that the not(selected) statement is
not working anymore with the spanish language. If I switch back to Default
or English, the not(selected) statement is working again. On the other hand,
solved?
mitche...@gmail.com
works for me this way.
see attached.
Loop_with_not_selected.xls (29.5 KB)
> Kind regards,
>> locallized name.
>>> I see the problem: In the loop-repeat, I am forcing the form to use only
>>> one value at the time, while setting this value to a string. On this
>>> moment, the value becomes language dependant. So I need to find a way how I
>>> can reset the selected value to a language independant value (as you said,
>>> by using the 'name' column). I can't figure out how I can do this.
>>>>> Kind regards,
>>>>> Eddy
>>>>>> Hi Gabriel,
>>>>>> Regards,
>>>>>> Eddy
>>>>>>> the same.
>>>>>>>> Dear all,
>>> Groups "ODK Community" group.
>>> an email to opendatakit...@googlegroups.com.
>> Mitch Sundt
>> Software Engineer
>> mitche...@gmail.com
Thanks again Yaw and Gabriel,
It still not working. I don't know what it is. About the string solution I
don't know how to use this. I leave it like this because this all costs me
too much time to solve. Anyway, thanks again for the fast responses, very
kind.
Kind regards,
Eddy
> see attached.
>> Kind regards,
>>> locallized name.
>>>>>> Kind regards,
>>>>>> Eddy
>>>>>>> Hi Gabriel,
>>>>>>> Regards,
>>>>>>> Eddy
>>>>>>>> the same.
>>>>>>>>> Dear all,
>>> Mitch Sundt
>>> Software Engineer
>>> mitche...@gmail.com
