I have installed the ODK Application Designer 2.0 and most the required libraries - npm,Grunt and etc.
I have my Android Studio up and running.
Question is: how do i obtain the android code from the ODK Application Designer so that i can view it?
or Which folders should i copy to my android sdk?
We have 3 code bases for our Android apps - Survey, Tables, and Services.
The repos for these apps can be found at https://github.com/opendatakit.
We don't anticipate that most of our users will make modifications to these
code bases. Of course, you are welcome to if that fits your needs. With
the 2.0 tools, we expect most of our users to do their development in
JavaScript for Tables and Excel for Survey. If you have created Survey
forms using the Application Designer and now would like to move them to the
device, you should install Survey, Tables, and Services from
https://opendatakit.org/downloads. Then you can follow the directions at
https://opendatakit.org/use/2_0_tools/active-distribution/application-designer-rev-206/#Both_Pushing_updates_to_the_Device
to push updates to your device. If you are new to the ODK 2.0 tools, we
recommend going through the getting started page at
https://opendatakit.org/use/2_0_tools/active-distribution/2-0-getting-started-rev-206/
Clarice
On Tue, Oct 11, 2016 at 7:41 AM, wrote:I have installed the ODK Application Designer 2.0 and most the required
or Which folders should i copy to my android sdk?--
"ODK Developers" group.
