I intend to use a form with an "audit" type field and intend to get the data in the Power BI web service. Now the Power BI Submission in OData contains the file name in the Meta section of the submission but can someone please point out, how I can access the data from the audit.csv?
I can't find an endpoint for the audit.csv in the OData feed
It is not an issue as yet. Just wish to know the procedure.
Currently you cannot use OData endpoint to import the audit.csv for all Submissions. You have two options:
Download the zip file from the ODK Central and manually import "your_form - audit.csv" into PowerBI
Use download attachment endpoint for each Submissions to import in Power BI i.e. https://your_domain.getodk.cloud/v1/projects/1/forms/your_form/submissions/your_submission_id/attachments/audit.csv
You can write a custom function to fetch audit file for each submission, please take a hint from this https://community.fabric.microsoft.com/t5/Desktop/Create-tables-based-on-all-Query-Parameters/td-p/345947
Thank you @Sadiq_Khoja! You have been very helpful
