With the previous version, my form works
with this version the cascade filter don not work anyu more (no filter on a multiple choice question :every answer appear)
Hi @Fabienne35
Could you attach your form?
In fact it depend on the way of compiling my xlsform.
with off line 1;x it does not work
with online 2;x it works
Ok if it works with the newer version we can assume it's a fixed bug
A post was split to a new topic: Why is it that you cannot edit forms that are saved before sending?
