ODK 2 Tool Suite Release - v2.1.1
The latest release of the ODK 2 Tool Suite is now available for download!
The v2.1.1 tools are backward compatible with v2.1.0 BUT not backward compatible with previous versions (v2.0.*). The incompatibility is internal to the ODK tools, all external files such as XLSX forms, JavaScript/HTML, and server interfaces are unaffected. Most users should experience a smooth upgrade.
The ODK 2 Tool Suite is an alternative to the ODK 1.x Tool Suite rather than a replacement. ODK 2 is designed for complex workflows and information management. A simple migration path between 1.x and 2 does not yet exist because they are based on different standards.
Detailed documentation about the 2 Tool Suite can be found at https://docs.opendatakit.org/odk2 .
ODK v2.1.1 releases can be downloaded from:
Application Designer v2.1.1
Services v2.1.1
Suitcase v2.1.1
Survey v2.1.1
Tables v2.1.1
Version 2.1.1 rev 228 APKs are compatible with the Sync Endpoint. Aggregate is now deprecated.
This release includes:
Alpha Versions of
  • Submit
  • Sensors Framework
  • Zebra Printer Driver
Changes
  • Upgraded Android Gradle plugin and various support libraries
  • Updated Spanish translations
  • Fixed Sensors framework and Zebra Printer Driver
  • Fixed Tables MapListViewFragment to update the list when a marker is clicked on the map
  • Disable scrolling of ODK Survey navbar
  • Fix text overflow in ODK Survey select prompts
Resolved issues:
  • #1410 Survey form name overflow
Documentation for getting started with the Sync Endpoint is available at:
• https://docs.opendatakit.org/odk2/sync-endpoint/
