ODK 2 Tool Suite Release - v2.1.2
The latest release of the ODK 2 Tool Suite is now available for download!
The v2.1.2 tools are backward compatible with v2.1.0 BUT not backward compatible with previous versions (v2.0.*). The incompatibility is internal to the ODK tools, all external files such as XLSX forms, JavaScript/HTML, and server interfaces are unaffected. Most users should experience a smooth upgrade.
The ODK 2 Tool Suite is an alternative to the ODK 1.x Tool Suite rather than a replacement. ODK 2 is designed for complex workflows and information management. A simple migration path between 1.x and 2 does not yet exist because they are based on different standards.
Detailed documentation about the ODK 2 Tool Suite can be found at:
https://docs.opendatakit.org/odk2
ODK v2.1.2 releases can be downloaded from:
Application Designer v2.1.2
Services v2.1.2
Suitcase v2.1.2
Survey v2.1.2
Tables v2.1.2
Version 2.1.2 rev 230 APKs are compatible with the Sync Endpoint. Aggregate is now deprecated.
This release includes:
Changes
• Fix uri parsing of files for Tables CSV import functionality
• Fix acknowledge prompt type text
• Convert to 2-character language codes
• Fix text overflow in select prompt type
• Upgrade Android Gradle plugin and various libraries
Documentation for getting started with the Sync Endpoint is available at:
https://docs.opendatakit.org/odk2/sync-endpoint/
