Well, it´s not perfect but it works for me:
i do call to progress which is just a status bar, and obviously you´ll have
to make it work to read the links in the columns where you have it.
That´s the main module, but I use much more but I am not allowed to share
them all, if you know what you are doing then you are already close enough.
Sub DownloadPics2()
Application.ScreenUpdating = True
Dim ws As Worksheet
Dim Lastrow As Long, i As Long, j, k As Long
Dim strPath As String
Dim porcentaje As Single
Dim respuesta, respuesta2 As Integer
Dim basura As String
ActiveSheet.Name = "Export"
Set ws = Sheets("Export")
'~~> Name of the sheet which has the list
'Miro cuantas lineas hay y las compruebo todas
respuesta = MsgBox("¿do you wanna download the pictures? It can take
some time", vbYesNo + vbQuestion, "report")
If respuesta = vbYes Then
respuesta2 = MsgBox("¿do you wanna add already existing pictures (so it
does not download themn again)? if you do then drop then in the next window
" & CARPETA, vbYesNo + vbQuestion, "Reporte campaña")
If respuesta2 = vbYes Then
basura = FilePath2
End If
Lastrow = ws.Range("B" & Rows.count).End(xlUp).Row
For i = 2 To Lastrow '<~~ 2 because row 1 has headers
For j = 8 To 18
If ws.Cells(i, j).Value <> "" Then
If j >= 8 Then
'MsgBox "es la primera"
strPath = ws.Range("d" & i).Value & "_" & (j - 7) & ".jpg"
If Dir(CARPETA & "\" & strPath) <> "" Then
'MsgBox "existe el primero"
For k = 8 To 18
If ws.Cells(i, k).Value <> "" Then
'MsgBox "escribo link existente"
strPath = ws.Range("d" & i).Value & "_" & (k -
& ".jpg"
ws.Hyperlinks.Add Anchor:=ws.Cells(i, k),
Address:=CARPETA & "" & strPath, TextToDisplay:=strPath
End If
Next k
j = 19
End If
End If
If j <> 19 Then
Ret = URLDownloadToFile(0, ws.Cells(i, j).Value, CARPETA &
"" & strPath, 0, 0)
If Ret = 0 Then
ws.Hyperlinks.Add Anchor:=ws.Cells(i, j),
Else
ws.Cells(i, j).Value = "ERROR DE DESCARGA"
ws.Cells(i, j).Interior.Color = 250
End If
End If
End If
porcentaje = Format(((11 * (i - 2) + (j - 8)) / ((Lastrow - 1) *
11)) * 100, "standard") 'Format(i / (LastRow + 1) * 100, "standard")
Progress porcentaje
Next j
Next i
Else
'do nothing
End If
End Sub
On Fri, Feb 5, 2016 at 6:27 AM, Ayoub Kakande wrote:
Pablo hi,
Would like to know more about those macros of yours, more especially do
they link images to excel
On 4 February 2016 at 18:01, Pablo Rodríguez < nuncaestardesillegaspronto@gmail.com> wrote:
Hi guys, I´m having another issue, (that I solve in another way). I
export the database in a CSV and then download the images and everything
with excel macros, but, now the exports are without extension with the name
"binaryData". Inside it is basically a CSV, so it is not a serious problem
with the program I wrote, now i just programed it so it basically starts by
adding the csv extension, but just saying about this other issue.
Regards,
Pablo
On Thu, Feb 4, 2016 at 1:28 PM, rivera.raffy@gmail.com wrote:
Hi guys,
just want to ask when will the new version (that solves filtering
issues) be available?
Thanks.
Raffy
https://groups.google.com/d/topic/opendatakit/CtQqeSVlNq8/unsubscribe.
**In sun set years education is not associated with standard of living and
medical care access; it is the the financial myosin and actin!!!
**** Don't give me fish, teach me how to fish
Kayoub K
0772656158 / 0703516660
Data Manager
Mujhu Research Collaboration
Mulago Hosp
Msc Enterprise Architecture
