I have installed ODK Aggregate on Tomcat on Windows server 2016, which is working.
I'm connecting with a PostgreSQL database on MS Azure that WAS configured to enforce SSL connections.
I had to disable this setting as I can't find where I can configure the PostgreSQL connection settings after installation to make KOBO Aggregate connect to Postgre over SSL.
I have not found any configuration file or anything that allows me to do this.
If someone could point me in the right direction?
Regards,
Erik
OK, fixed it myself
Thanks to this topic: JSON change-password request to /ssl/user-manage-passwords failed - #12 by Axlm
I found this post from @ggalmazor :
* Stop Tomcat
* Create a backup of the whole directory where Aggregate is deployed
* Unzip WEB-INF/lib/ODKAggregate-settings.jar into WEB-INF/classes
* Delete WEB-INF/lib/ODKAggregate-settings.jar << this is important
* Edit WEB-INF/classes/security.properties and set security.server.hostname with the IP address or hostname that the users will be using to access Aggregate
* Start Tomcat
There i found jdbc.properties in which the postgresql url is configured.
jdbc.url=jdbc:postgresql://sqlserver.mydomain.com/odk_prod?autoDeserialize=true
According to the documentation @ https://jdbc.postgresql.org/documentation/head/connect.html adding "?ssl=true" to the url should do the trick.
well, it did and ODKAggregate now connects to a postgresql database that enforces ssl connections.
