On ODK Aggregate, when i want to export my data to .csv file,Its shows me
error (Failure - will retry later).
I notice when data size more than 100 row or data table is big then only
this error occur. Can any one please give some idea about how to resolved
from this error.
Dear all, Alternatively i used ODK Briefcase to export my data to .csv
file. but which is giving two file rather than single file.
basically this is happen, when i used begin repeat type of questions in my
form.
when i export same form through ODK Aggregate's export option it gives only
one file.which is far better than ODK Briefcase export.
After lots of research finally i found a solution which is increasing the max_allowed_packet size in my mysql or postgreSQL databases containing the ODKAggregate Database and the failure retry later issue is resolved:
set global max_allowed_packet = 1073741824;
Bests
On Friday, January 31, 2014 at 4:33:50 PM UTC+4:30, Kanhu Bhol wrote:
> Hello Friends,
> On ODK Aggregate, when i want to export my data to .csv file,Its shows me error (Failure - will retry later).
> I notice when data size more than 100 row or data table is big then only this error occur. Can any one please give some idea about how to resolved from this error.
> Thanks
> Kanhu
Finally found the right solution which is increasing the max_allowed_packet size in MySQL or PostgreSQL database engines, and the Failure - will retry later issue will go away:
cheers,
> Hello Friends,
> Thanks
> Kanhu
I´m kind of new here, but I Already have this problem:
I tried to go into the cloud shell and type:
nothing happend, I have the same problem, and as you can imaging it´s the worst moment to happend... I tried to take the csv file from ODK Briefcase by first pulling all the information, when pulling it at some point it says "FAILED" But I think it might be downloading everything so I can generate the CSV file, but instead of links to the media of my forms in the cloud it give me links to my local folder... a bummer... any help?
El viernes, 31 de enero de 2014, 13:03:50 (UTC+1), Kanhu Bhol escribió:
> Hello Friends,
> Thanks
> Kanhu
"CSV files are a text only, tabular representation of the data.
Multimedia files are represented by including standard web links to
the files. Repeats are also represented with links to the underlying
data. Grouping information is not preserved. Metadata is only
preserved if a filter is created with the metadata.
To download CSV files of forms with repeats, consider using ODK
Briefcase instead of ODK Aggregate's export functionality. Instead of
repeats that are represented with links to the underlying data, ODK
Briefcase will export a set of CSV files, one for each repeating
group. ODK Briefcase will also export any multimedia as files (e.g.,
pictures will get exported as JPEGs). The only metadata that is
preserved is the submission date in the CSV is preserved, but the XML
files that ODK Briefcase downloads has all form metadata."
Basically, you should use ODK Briefcase because it gives you all the
CSV data in one go. Yes it exports multiple files, but that is because
multiple files are the best way to represent the repeat structure you
use.
Dear all, Alternatively i used ODK Briefcase to export my data to .csv file.
form.
This issue should have been addressed in ODK Aggregate v1.3.
It was introduced by moving to LONGBLOB in ODK Aggregate v1.2.
What version of ODK Aggregate are you using?
Hello Friends,
from this error.
Kanhu
Hello Guys,
Bests
Hello Friends,
Kanhu
Good day,
Please assist with the steps. im stuck with this retry later error
If you are still having problems, please start a new thread describing
what you've tried so far.
Hello Friends,
Kanhu
Hi guys,
On Tue, May 3, 2016 at 10:17 AM, Yaw Anokwa wrote:
Hi there,
in-field training, and software development for ODK. Go to https://nafundi.com to get started.
Hello Friends,
Kanhu
Hi guys,
Hello Friends,
Kanhu
Hi guys,
Hello Friends,
Kanhu
Hi guys,
