I have been trying to setup an instance of ODK collect on a Flynn server.
But there is some issue when setting up something related to docker-compose
I cloned the repo from github and followed the instructions about database setup and first steps.
Alter that i executed gradle build locally and pushed the repo to my flynn instance.
It returned the following error:
FAILURE: Build failed with an exception.
* Where:
Build file '/tmp/build/app/build.gradle' line: 26
* What went wrong:
A problem occurred evaluating root project 'aggregate'.
> Failed to apply plugin [id 'docker-compose']
> Could not create an instance of type com.avast.gradle.dockercompose.Com poseExtension_Decorated.
this is my build.gradle:
import static org.opendatakit.aggregate.gradle.Util.getVersionName
buildscript {
repositories {
jcenter()
dependencies {
classpath 'de.richsource.gradle.plugins:gwt-gradle-plugin:0.6'
classpath 'de.undercouch:gradle-download-task:3.3.0'
classpath "com.avast.gradle:gradle-docker-compose-plugin:0.6.8"
classpath 'org.akhikhl.gretty:gretty:+'
plugins {
id 'java'
id 'maven'
id 'war'
id 'idea'
id 'checkstyle'
id 'de.fuerstenau.buildconfig' version '1.1.8'
apply plugin: 'gwt'
apply plugin: 'de.undercouch.download'
apply plugin: 'org.akhikhl.gretty'
apply plugin: 'docker-compose'
group = 'org.opendatakit'
version = getVersionName()
description = ""
sourceCompatibility = 1.7
targetCompatibility = 1.7
repositories {
mavenCentral()
flatDir {
dirs 'libs'
def versions = [
spring : '4.3.4.RELEASE',
springSecurity: '4.2.0.RELEASE',
gwt : [
servlet : '2.7.0',
googleMapsV3 : '1.0.1',
visualization: '1.1.2'
jackson : '2.8.5',
geronimo : '1.0',
httpcomponents: [
client: '4.5.2',
core : '4.4.5',
mime : '4.5.2'
commons : [
lang3 : '3.5',
fileUpload: '1.3.2',
dbcp2 : '2.1.1'
googleApi : [
client: '1.22.0',
sheets: 'v4-rev38-1.22.0',
drive : 'v3-rev52-1.22.0'
wink : '1.4',
gson : '2.8.0',
kxml2 : '2.3.0',
odk : [
javarosa : '2.6.0',
httpclientGae: '4.5.2-1',
tomcatUtil : '1.0.1'
jdbc : [
mysql : '5.1.44',
postgresql: '42.1.4.jre7'
gae : '1.9.54',
odkTomcatUtil : '1.0.1',
servletApi : '3.1.0',
junit : '4.12',
mockito : '2.+'
configurations.all {
exclude group: 'commons-logging', module: 'commons-logging'
dependencies {
compile group: 'org.slf4j', name: 'slf4j-api', version: '1.7.25'
compile group: 'org.slf4j', name: 'jcl-over-slf4j', version: '1.7.25' // JCL over SLF4J
compile group: 'org.slf4j', name: 'log4j-over-slf4j', version: '1.7.25'
compile group: 'org.slf4j', name: 'slf4j-jdk14', version: '1.7.25'
compile group: 'org.opendatakit', name: 'odk-tomcatutil', version: versions.odk.tomcatUtil
compile group: 'org.springframework', name: 'spring-aop', version: versions.spring
compile group: 'org.springframework', name: 'spring-aspects', version: versions.spring
compile group: 'org.springframework', name: 'spring-beans', version: versions.spring
compile group: 'org.springframework', name: 'spring-context', version: versions.spring
compile group: 'org.springframework', name: 'spring-context-support', version: versions.spring
compile group: 'org.springframework', name: 'spring-core', version: versions.spring
compile group: 'org.springframework', name: 'spring-expression', version: versions.spring
compile group: 'org.springframework', name: 'spring-instrument', version: versions.spring
compile group: 'org.springframework', name: 'spring-jdbc', version: versions.spring
compile group: 'org.springframework', name: 'spring-tx', version: versions.spring
compile group: 'org.springframework', name: 'spring-instrument-tomcat', version: versions.spring
compile group: 'org.springframework', name: 'spring-web', version: versions.spring
compile group: 'org.springframework.security', name: 'spring-security-config', version: versions.springSecurity
compile group: 'org.springframework.security', name: 'spring-security-core', version: versions.springSecurity
compile group: 'org.springframework.security', name: 'spring-security-crypto', version: versions.springSecurity
compile group: 'org.springframework.security', name: 'spring-security-web', version: versions.springSecurity
compile group: 'com.googlecode.gwt-google-maps-v3', name: 'gwt-google-maps-v3', version: versions.gwt.googleMapsV3
compile group: 'com.google.gwt.google-apis', name: 'gwt-visualization', version: versions.gwt.visualization
compile group: 'com.google.gwt', name: 'gwt-servlet', version: versions.gwt.servlet
compile group: 'com.fasterxml.jackson.core', name: 'jackson-annotations', version: versions.jackson
compile group: 'com.fasterxml.jackson.core', name: 'jackson-core', version: versions.jackson
compile group: 'com.fasterxml.jackson.core', name: 'jackson-databind', version: versions.jackson
compile group: 'com.fasterxml.jackson.dataformat', name: 'jackson-dataformat-xml', version: versions.jackson
compile group: 'com.fasterxml.jackson.jaxrs', name: 'jackson-jaxrs-json-provider', version: versions.jackson
compile group: 'com.fasterxml.jackson.jaxrs', name: 'jackson-jaxrs-xml-provider', version: versions.jackson
compile group: 'org.apache.geronimo.specs', name: 'geronimo-jaxrs_1.1_spec', version: versions.geronimo
compile group: 'org.apache.httpcomponents', name: 'httpclient', version: versions.httpcomponents.client
compile group: 'org.apache.httpcomponents', name: 'httpcore', version: versions.httpcomponents.core
compile group: 'org.apache.httpcomponents', name: 'httpmime', version: versions.httpcomponents.mime
compile group: 'org.apache.commons', name: 'commons-lang3', version: versions.commons.lang3
compile group: 'org.apache.commons', name: 'commons-dbcp2', version: versions.commons.dbcp2
compile group: 'commons-fileupload', name: 'commons-fileupload', version: versions.commons.fileUpload
compile group: 'com.google.api-client', name: 'google-api-client', version: versions.googleApi.client
compile group: 'com.google.api-client', name: 'google-api-client-appengine', version: versions.googleApi.client
compile group: 'com.google.apis', name: 'google-api-services-sheets', version: versions.googleApi.sheets
compile group: 'com.google.apis', name: 'google-api-services-drive', version: versions.googleApi.drive
compile group: 'org.apache.wink', name: 'wink-common', version: versions.wink
compile group: 'org.apache.wink', name: 'wink-server', version: versions.wink
compile group: 'com.google.code.gson', name: 'gson', version: versions.gson
compile group: 'net.sf.kxml', name: 'kxml2', version: versions.kxml2
compile group: 'org.opendatakit', name: 'opendatakit-javarosa', version: versions.odk.javarosa
compile group: 'org.opendatakit', name: 'odk-httpclient-gae', version: versions.odk.httpclientGae
compile group: 'mysql', name: 'mysql-connector-java', version: versions.jdbc.mysql
compile group: 'org.postgresql', name: 'postgresql', version: versions.jdbc.postgresql
compile group: 'org.opendatakit', name: 'odk-tomcatutil', version: versions.odkTomcatUtil
compile group: 'com.google.appengine', name: 'appengine-api-1.0-sdk', version: versions.gae
compile group: 'com.google.appengine', name: 'appengine-api-labs', version: versions.gae
compile group: 'com.google.appengine', name: 'appengine-jsr107cache', version: versions.gae
compileOnly group: 'javax.servlet', name: 'javax.servlet-api', version: versions.servletApi
testCompile group: 'junit', name: 'junit', version: versions.junit
testCompile group: 'org.springframework', name: 'spring-test', version: versions.spring
testCompile group: 'com.google.appengine', name: 'appengine-api-stubs', version: versions.gae
testCompile group: 'com.google.appengine', name: 'appengine-testing', version: versions.gae
testCompile group: 'org.mockito', name: 'mockito-core', version: versions.mockito
task wrapper(type: Wrapper) {
gradleVersion = "2.1"
gwt {
gwtVersion = versions.gwt.servlet
modules 'org.opendatakit.aggregate.AggregateUI'
minHeapSize = "512M"
maxHeapSize = "1024M"
war {
if (warMode == "installer") {
println "Excluding Guava from WAR"
war.rootSpec.exclude("**/guava*.jar")
println "Excluding config files from WAR"
war.rootSpec.exclude "jdbc.properties"
war.rootSpec.exclude "logging.properties"
war.rootSpec.exclude "odk-common-security-settings.xml"
war.rootSpec.exclude "odk-security-settings.xml"
war.rootSpec.exclude "odk-settings.xml"
war.rootSpec.exclude "security.properties"
gretty {
contextPath = '/'
host = 'localhost'
logDir = 'logs'
buildConfig {
appName = 'ODK Aggregate'
clsName = 'BuildConfig'
packageName = 'org.opendatakit.aggregate.buildconfig'
// Required to use fileExtensions property in checkstyle file
checkstyle {
toolVersion = '7.6.1'
dockerCompose {
postgresql {
useComposeFiles = ['db/postgresql/docker-compose.yml']
mysql {
useComposeFiles = ['db/mysql/docker-compose.yml']
apply from: 'common.gradle'
apply from: 'gae.gradle'
apply from: 'installer.gradle'
apply from: 'packer.gradle'
