Hi ,
I am trying to set up a ODK aggregate server with sql server17 and tomcat 8.5 on windows 8 machine using the ODK Aggregate v1.4.15 windows- installer.
Even after following all the steps , I couldn't able to access the ODK aggregate server. Getting 404 error. Anyone help me resolve this issue.
Getting following errors in the tomcat log file.
WARNING: Datastore failure: refreshReachableGrantedAuthorities -- adjusting retry time
Dec 26, 2017 12:53:05 PM org.springframework.web.context.support.XmlWebApplicationContext refresh
WARNING: Exception encountered during context initialization - cancelling refresh attempt: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'hierarchicalRoleRelationships' defined in ServletContext resource [/WEB-INF/applicationContext-security.xml]: Invocation of init method failed; nested exception is org.opendatakit.common.persistence.exception.ODKDatastoreException: org.springframework.transaction.CannotCreateTransactionException: Could not open JDBC Connection for transaction; nested exception is java.sql.SQLException: Cannot create PoolableConnectionFactory (The connection to the host MMAHENDRAN-IN, named instance mssqlserver01 failed. Error: "java.net.SocketTimeoutException: Receive timed out". Verify the server and instance names and check that no firewall is blocking UDP traffic to port 1434. For SQL Server 2005 or later, verify that the SQL Server Browser Service is running on the host.)
Dec 26, 2017 12:53:05 PM org.springframework.scheduling.concurrent.ThreadPoolTaskScheduler shutdown
INFO: Shutting down ExecutorService 'task_scheduler'
Dec 26, 2017 12:53:05 PM org.springframework.web.context.ContextLoader initWebApplicationContext
SEVERE: Context initialization failed
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1583)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:553)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:754)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:866)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:542)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:444)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:326)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4745)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5207)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:752)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:728)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:734)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:986)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1857)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: org.opendatakit.common.persistence.exception.ODKDatastoreException: org.springframework.transaction.CannotCreateTransactionException: Could not open JDBC Connection for transaction; nested exception is java.sql.SQLException: Cannot create PoolableConnectionFactory (The connection to the host MMAHENDRAN-IN, named instance mssqlserver01 failed. Error: "java.net.SocketTimeoutException: Receive timed out". Verify the server and instance names and check that no firewall is blocking UDP traffic to port 1434. For SQL Server 2005 or later, verify that the SQL Server Browser Service is running on the host.)
at org.opendatakit.common.persistence.engine.sqlserver.DatastoreImpl.assertRelation(DatastoreImpl.java:713)
at org.opendatakit.common.security.spring.GrantedAuthorityHierarchyTable.assertRelation(GrantedAuthorityHierarchyTable.java:115)
at org.opendatakit.common.security.spring.GrantedAuthorityHierarchyTable.getEntireGrantedAuthorityHierarchy(GrantedAuthorityHierarchyTable.java:186)
at org.opendatakit.common.security.spring.RoleHierarchyImpl.buildRolesReachableInOneStepMap(RoleHierarchyImpl.java:465)
at org.opendatakit.common.security.spring.RoleHierarchyImpl.refreshReachableGrantedAuthorities(RoleHierarchyImpl.java:282)
at org.opendatakit.common.security.spring.RoleHierarchyImpl.afterPropertiesSet(RoleHierarchyImpl.java:132)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1642)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1579)
... 25 more
Caused by: org.springframework.transaction.CannotCreateTransactionException: Could not open JDBC Connection for transaction; nested exception is java.sql.SQLException: Cannot create PoolableConnectionFactory (The connection to the host MMAHENDRAN-IN, named instance mssqlserver01 failed. Error: "java.net.SocketTimeoutException: Receive timed out". Verify the server and instance names and check that no firewall is blocking UDP traffic to port 1434. For SQL Server 2005 or later, verify that the SQL Server Browser Service is running on the host.)
at org.springframework.jdbc.datasource.DataSourceTransactionManager.doBegin(DataSourceTransactionManager.java:252)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.getTransaction(AbstractPlatformTransactionManager.java:373)
at org.opendatakit.common.persistence.engine.sqlserver.DatastoreImpl.assertRelation(DatastoreImpl.java:558)
... 32 more
Caused by: java.sql.SQLException: Cannot create PoolableConnectionFactory (The connection to the host MMAHENDRAN-IN, named instance mssqlserver01 failed. Error: "java.net.SocketTimeoutException: Receive timed out". Verify the server and instance names and check that no firewall is blocking UDP traffic to port 1434. For SQL Server 2005 or later, verify that the SQL Server Browser Service is running on the host.)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2294)
at org.apache.commons.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:2039)
at org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:1533)
at org.springframework.jdbc.datasource.DataSourceTransactionManager.doBegin(DataSourceTransactionManager.java:211)
... 34 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The connection to the host MMAHENDRAN-IN, named instance mssqlserver01 failed. Error: "java.net.SocketTimeoutException: Receive timed out". Verify the server and instance names and check that no firewall is blocking UDP traffic to port 1434. For SQL Server 2005 or later, verify that the SQL Server Browser Service is running on the host.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:227)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.getInstancePort(SQLServerConnection.java:5080)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.primaryPermissionCheck(SQLServerConnection.java:1830)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:1594)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectInternal(SQLServerConnection.java:1458)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:840)
at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:561)
at org.apache.commons.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:39)
at org.apache.commons.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:256)
at org.apache.commons.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:2304)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2290)
... 37 more
Dec 26, 2017 12:53:05 PM org.apache.catalina.core.StandardContext listenerStart
SEVERE: Exception sending context initialized event to listener instance of class [org.springframework.web.context.ContextLoaderListener]
... 25 more
... 32 more
... 34 more
... 37 more
Dec 26, 2017 12:53:05 PM org.apache.catalina.core.ApplicationContext log
INFO: Closing Spring root WebApplicationContext
