Did you run the database configuration script that the installer
generated? That should have created the username and password that ODK
Aggregate uses.
For MySQL, a common problem is to forget to install the MySQL
Connector/J into the Tomcat lib directory.
The server configuration is described here:
http://code.google.com/p/opendatakit/wiki/AggregateDeploymentConfiguration
The jdbc connection settings are in jdbc.properties
On Fri, Mar 8, 2013 at 1:41 AM, mbd.rose@gmail.com wrote:
I am having a similar problem. I have set up Tomcat on the server
machine and the default Tomcat 6 page shows up, no problem there. When I
tried to deploy ODK aggregate and start up Tomcat I can still get the
default page, but when starting up Tomcat throws the following exception:
Exception: ------
java.sql.SQLException: Access denied for user 'lbwsatserver'@'localhost'
(using
password: YES)
Is it possible to check the password that ODK is providing, and/or
manually change it? As a consequence localhost/ODKAggregate returns a 404
error, or just says it cannot connect.
Cheers,
Matt Rose
UCL/MIRA Kathmandu
On Friday, 13 July 2012 22:15:05 UTC+5:45, Mitch wrote:
Before proceeding to deploying ODK Aggregate, you should first get the
default Tomcat 6 server page to display. If you don't know what that
should look like, install Tomcat on a computer without IIS running, and
open a browser to the port the Tomcat server is running on.
Until you can get that Tomcat 6 server page to show on your IIS
server, you are still working through the generic problem of configuring
IIS and Tomcat to coexist on the same server. A Microsoft certified
systems engineer should be able to help with this, or anyone familiar with
Tomcat configuration.
Once you do get the Tomcat 6 server page to show, you should then be
able to deploy ODK Aggregate and it should just work. i.e., this is
unlikely to be a problem specific to ODK Aggregate.
On Fri, Jul 13, 2012 at 1:02 AM, irum.jamshed < irum.j...@pakistan.theirc.org> wrote:
Anybody
can guide me on the following issue:
On server machine Microsoft IIS
already configured as primary Internet Server. We have installed the
Tomcat,
MySQL and ODK aggregate as per the instruction mentioned at
http://opendatakit.org/use/aggregate/tomcat-install/ but we are unable to
run ODK
aggregate. We feel some different port settings for the configuration
of ODK
aggregate as IIS already running on the server.
Please provide us step by step
configuration of ODK aggregate when IIS already installed on the server
(Windows 2003).
Irum Jamshed | Manager - Data Management
International Rescue Committee
Irum.Jamshed@pakistan.theirc.org | +92
91 5703310 (Ext-105) | rescue.org
mitche...@gmail.com
an email to opendatakit-developers+unsubscribe@googlegroups.com.
https://groups.google.com/d/topic/opendatakit-developers/2NH6oprWS_k/unsubscribe?hl=en
