Dear all,
I failed to get ODK Aggregate and Collect to play well together in my
previous effort and have not decided to install everything from
scratch on a brand new computer with nothing installed. I downloaded
ODK Aggregate v1.0 beta rev 4 (windows installer), Postgres, Tomcat,
JDK 7. I have followed the instructions on http://code.google.com/p/opendatakit/wiki/AggregatePostgresqlInstall
and when I get to the last point, running the Aggregate Installer, on
double clicking it i get an error: Error running C:/glassfish3/jdk7/
jre/bin/java.exe QualifiedHostname: Error: Could not find or load main
class QualifiedHostname".... is this a problem with the installer?
does installer work with JDK 7?
make sure Tomcot is correctly installed/configured ... Then run the ODK
installer
On Wed, Sep 7, 2011 at 4:15 PM, Tumaini Kilimba wrote:
Dear all,
A,also im having the same issue, I think there is missing jar ot war file/s
on my system, Im trying to figure our.
For Oracle Java SDK 1.7 the error is:
Log started 12/01/2012 at 19:48:02
Preferred installation mode : win32
Trying to init installer in mode win32
Mode win32 successfully initialized
Setting variable default_hostname from C:/Program
Files/Java/jdk1.7.0_09/jre/bin/java.exe QualifiedHostname
Script exit code: 1
Script output:
Script stderr:
Error: Could not find or load main class QualifiedHostname
Error running C:/Program Files/Java/jdk1.7.0_09/jre/bin/java.exe
QualifiedHostname : Error: Could not find or load main class
QualifiedHostname
For Oracle Java 1.6 the error is:
Log started 12/01/2012 at 19:35:19
Files/Java/jdk1.6.0_26/jre/bin/java.exe QualifiedHostname
Script exit code: 1
Script output:
Script stderr:
java.lang.NoClassDefFoundError: QualifiedHostname
Caused by: java.lang.ClassNotFoundException: QualifiedHostname
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
Could not find the main class: QualifiedHostname. Program will exit.
Exception in thread "main"
Error running C:/Program Files/Java/jdk1.6.0_26/jre/bin/java.exe
QualifiedHostname : java.lang.NoClassDefFoundError: QualifiedHostname
Hey Mitch.
Same problem again ... suspect clash with pre-existing instance on this machine (Liferay Vaadin, running tomcat).
Windows 7 Ultimate, Java 6 and Java 7 runtimes present.
Bitrock installer creates any files in temp folder, but no ODK folder
Tried ODK Aggregate V1.4 and V1.32, same error (See log).
Local vars ....
C:\Users\Robin>ECHO %TEMP%
C:\Users\Robin\AppData\Local\Temp
Log started 11/10/2013 at 13:58:53
Setting variable default_hostname from C:/Program Files (x86)/Java/jre6/bin/java.exe QualifiedHostname
Script exit code: 1
Script output:
Script stderr:
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
Error running C:/Program Files (x86)/Java/jre6/bin/java.exe QualifiedHostname : java.lang.NoClassDefFoundError: QualifiedHostname
Apologies if this comes through twice - first post seems to have gone missing.
I am in the same boat as the other authors.
Tried Aggregate 1.34 and 1.4, same issues with Qualified Hostname directory.
I do not get past the splash screen before the error comes up.
Files are created in temp folder, but no ODK-asdsad-asdsad folder.
( Only folder created is sans ODK prefix ... be29e7f1-71ae-4703-50cb-1d52be512f51
Suspect clash with existing Liferay-Vaadin Tomcat instance ?
( Or something changing the folder prefix ?)
C:\Users\Robin>java -version
java version "1.6.0_26"
Java(TM) SE Runtime Environment (build 1.6.0_26-b03)
Java HotSpot(TM) 64-Bit Server VM (build 20.1-b02, mixed mode)
Script exit code: 1
Script output:
Script stderr:
Funny how they say this is easy, but I've been at it all afternoon and nothing works like it's supposed to. Files that are supposed to be .exe aren't. I tried installing the generic version, but there is not setup file to run.
Giving up.
Tomcat works fine, when I go to http://localhost I am taken to the
Tomcat Welcome page....
> installer
> > Dear all,
> > Thanks in advance,
> > Tumaini
> Regards,
> *BoddiReddy Purnachander*
> Mobile No: +91 8143812001
Have just tried re-installing Tomcat (it works fine), and downgrading
to JDK6 as opposed to JDK7, but the installer fails at the first
hurdle error message being: "Error running C:/Program Files/Java/
jdk1.6.0_27/jre/bin/java.exe QualifiedHostname :
java.lang.NoClassDefinitionFoundError: QualifiedHostname.... "
Anyone tell me what I could be doing wrong?
> installer
> > Dear all,
> > Thanks in advance,
> > Tumaini
> Regards,
What are your TEMP and/or TMP environment variables set to?
To determine those values, open a CMD window and type:
echo %TEMP%
echo %TMP%
And, if you look in those directories, you should fine a
bitrock_installer_nnnn.log (where nnnn is some number).
Please send me the most recent of these bitrock_installer log files, and the
values for the TEMP and TMP variables.
The installer will create a directory underneath the TEMP directory (with a
name of ODK-...) where it explodes various files and runs the
QualifiedHostname java program. It then copies those files into an "ODK
Aggregate" directory underneath the directory you specify during the
installation.
It is likely that you either don't have permissions to write or execute
programs within the TEMP directory. Hopefully the log files will give some
indication of the problem.
installer
On Wed, Sep 7, 2011 at 4:15 PM, Tumaini Kilimba tkili...@ihi.or.tz wrote:
Dear all,
I looked and found the very latest bitrock_installer and its contents
are as pasted below:
Log started 09/07/2011 at 17:06:38
Setting variable default_hostname from C:/Program Files/Java/
Script exit code: 1
Script output:
Script stderr:
Error running C:/Program Files/Java/jdk1.6.0_27/jre/bin/java.exe
I have not been able to determine what sort of permissions I have to
these folders as they are invisible to me when trying to view them in
Windows Explorer, I have to manually type in the file path i got from
running the echo %TEMP% command in the address bar. Hope all this
information is helpful in getting this sorted, the Health institute I
work in was intending to start piloting ODK by the end of October, so
it would be really helpful for me to get the hang of it now, rather
than later, as I am the proponent of ODK at the institute, and as
such, the lead developer/implementer of the ODK solution. Would you
say that that is an overly-ambitious timeline, considering I am still
at the first stage of implementing (setting up)? Your advice would be
much appreciated.
What antivirus / security software do you have installed?
Are you configured with a local or roaming profile?
Does this happen on other computers you have access to, or only this
computer?
The installer uses a directory (typically
C:\Users\username\AppData\Local\Temp, or perhaps ...\Roaming\Temp) to
create a subdirectory (ODK-xxxxxxxx-xxxx-xxxx-xxxxxxxxxxxx to store the
QualifiedHostname file that it is trying to run.
Can you see this ODK-... directory when you have started the installer? (it
should be removed after you close the installer). You may need to
explicitly type in AppData\Local\Temp or AppData\Roaming\Temp to access
those folders (they are normally hidden). If so, does it contain a
qualified_hostname subdirectory, containing QualifiedHostname.class ?
The error suggests that a command line (cmd) script that executes the
java.exe command is failing to change to this directory, or that there are
no files in this directory.
file/s on my system, Im trying to figure our.
Script exit code: 1
Script output:
Script stderr:
QualifiedHostname
Script exit code: 1
Script output:
Script stderr:
The installer does not actually install anything -- it just configures a
WAR file (for Tomcat installs) for subsequent copying into a
previously-configured Tomcat server or it generates a AppEngine directory
tree for subsequent uploading to Google AppEngine via an upload script.
So the existence of another webserver would not cause this problem.
I suspect some sort of interaction between your Java installation(s) and
antivirus software. The symptom appears to be that the Java software
doesn't know what its current working directory is, and so cannot find the
QualifiedHostname app to run it.
The best solution is to try a different computer. Once the installer has
generated the ODK Aggregate directory, you can copy it to another computer
(but I am not sure whether the issues with the first computer will prevent
it from running Tomcat or the AppEngine upload scripts).
Otherwise, if you do not have another computer available, you might try:
(1) After downloading the installer, rather than run it from within your
browser, open the directory containing the file (e.g.,
C:\Users\Robin\Downloads) with the "Windows Explorer" app, locate the
installer there, and double-click it.
(2) Try moving the installer to a different directory before
double-clicking it to run it.
(3) Specify a different directory location for it to use.
(4) Repeat above, but ensure that the directory names contain no non-latin
alphanumeric characters or characters with accents.
(5) Uninstalling your Java application and installing Oracle Java 7.
I have not heard of a successful work-around for this issue, other than
using a different computer; if any of the above work, let me know.
On Sun, Nov 10, 2013 at 3:43 AM, wrote:
Hey Mitch.
Local vars ....
Script exit code: 1
Script output:
Script stderr:
Note that the current install process will result in a website that you
cannot log into (you will get an error reported from Google about an
unrecognized domain).
Once you get that far, then you need to manually perform a sequence of
steps:
Follow-on notes:
(1) you need to ensure that the zip you end up with has the same directory
structure as the zip that you start with -- on Windows, it is easy to get
an extra directory inserted into the result.
(2) users have reported that zip on MacOSX does not work, and you need to
use the java jar command ( jar cf ../myjarfile.jar * )
to run.
Giving up.
I've tried the installer on a clean 32-bit Windows 7 system and have been
unable to replicate the problem, both when running as an administrator and
when running as an unprivileged user. I've also tried various combinations
of installations of JRE 7, JDK 7 + Glassfish, and JRE 6. All seem to work
through the hostname screen during a PostgreSQL install.
What version of Windows are you running?
Can you try running the installer on a different machine?
The installer requires a JRE but does not alter any settings on the machine;
you can run the installer without first having installed tomcat or
postgresql. If running on a different machine, be sure to change the
fully-qualified hostname to your target machine. The "ODK Aggregate"
directory that the installer produces contains the configured war file and
instructions on what to do with it. Once that directory is created, it (or
just the war file within it) can be copied as needed.
w.r.t. timeline: Not being able to use the ODK Aggregate 1.0 installer is a
big problem. If we can resolve that issue, whether the timelime is
reasonable depends upon how complex a form you need and how quickly you need
to ramp up everyone's use of ODK Collect & Aggregate during the pilot. If
you only need a simple form and can introduce ODK tools slowly to your
workforce, October is aggressive, but doable (assuming you can get past the
Aggregate installer issue).
On Thu, Sep 8, 2011 at 2:51 AM, Tumaini Kilimba wrote:
Thanks for the resoponse. The values are as follows:
Script exit code: 1
Script output:
Script stderr:
much appreciated.
Hi All,
I ve tried to install the beta version 1.0 everything work good but
I cant access it.It is asking for the ODK aggregate password.
Please Can someone help me to fix that and move forward.
Regards,
Patrice
On 8 sep, 14:42, Mitch Sundt wrote:
> Hi Tumaini,
> Mitch
> > echo %TEMP% : C:\Users\Tumaini\AppData\Local\Temp
> > echo %TMP% : C:\Users\Tumaini\AppData\Local\Temp
> > Script exit code: 1
> > Script output:
> > Script stderr:
> > much appreciated.
> > Tumaini
> > Thanks in advance
> Mitch Sundt
> Software Engineerhttp://www.OpenDataKit.org
> University of Washington
> mitchellsu...@gmail.com
During the install, you specify a Google Accounts e-mail account.
When you first visit the ODK Aggregate instance, you need to click "Sign in
with Google" and use that Google Accounts e-mail account. If you have
several such accounts, be sure to log into Google with the account you
specified before clicking this button.
Once logged in with this account, you can visit the Site Admin / Permissions
tab and add ODK Aggregate users; once they are added, you can set their
passwords. Only then can you click the "Sign in with Aggregate password"
and specify one of these users and their respective password.
On Thu, Sep 8, 2011 at 12:26 PM, Patrice CLEDO wrote:
Hi All,
and
combinations
work
machine;
and
(or
is a
need
If
the
Script exit code: 1
Script output:
Script stderr:
much appreciated.
Mitch,
Thanks a lot for your help.I figured it out before your mail but I still
have some trouble.The issue is I've installed the agregate test one before
and now i am
trying to lauch another one based on mysql and I thing have some conflict
but i have only one instance of the aggregate in mytomcat application
manager.I can't figure out what is wexactly the problem.It 's is blinking
butany data could not display in the web interface.
Your help you be greatly appreciate.
Patrice
On Thu, Sep 8, 2011 at 5:51 PM, Mitch Sundt wrote:
Hi Patrice,
Permissions tab and add ODK Aggregate users; once they are added, you can
set their passwords. Only then can you click the "Sign in with Aggregate
password" and specify one of these users and their respective password.
Hi All,
been
and
combinations
work
machine;
and
(or
is a
need
If
the
Script exit code: 1
Script output:
Script stderr:
at
at
much appreciated.
You can find the error log for Tomcat under (with a typical Windows install)
C:\Program Files\Tomcat\apache-tomcat-6.0.26\logs
The ones that usually contain errors are the catalina log files. Look in
the most recent log file (for simplicity, stop tomcat, delete the contents
of this directory, then restart tomcat and browse to the application; the
files that appear are the current log files).
If it complains about accessing the database, it is likely that you have not
executed the database configuration script or you specified improper values
for accessing the database server (e.g., if it is on a different host, you
didn't fill in the fully qualified hostname for the database server but left
it as 127.0.0.1).
If the error is not obvious, send that file as an attachment.
On Thu, Sep 8, 2011 at 3:41 PM, Patrice CLEDO wrote:
Mitch,
and now i am
in with Google" and use that Google Accounts e-mail account. If you have
Hi All,
been
and
combinations
work
machine;
and
(or
is a
need
If
the
Script exit code: 1
Script output:
Script stderr:
at
at
much appreciated.
Hi Mitch,
Let me send you the log files maybe you can see what is wrong with my
installation.
It should be noted that I tryed using my google account.Apprently in get
access to the aggregate platform in local.But It can't display all the
content of the page.Only the logo the help icons but they are blinking.First
time i see such thing.
install)
not executed the database configuration script or you specified improper
values for accessing the database server (e.g., if it is on a different
host, you didn't fill in the fully qualified hostname for the database
server but left it as 127.0.0.1).
Mitch,
and now i am
Hi All,
been
and
combinations
work
machine;
and
it (or
installer is a
you need
If
past the
contents
Script exit code: 1
Script output:
Script stderr:
at
exit.
QualifiedHostname
at
exit.
in
from
I
so
still
be
much appreciated.
