I loaded a local instance of ODKAggregate on my computer. I also
created some XForms, and I wanted to test to see how they look in
ODKCollect. I have an Android emulator set up on my local machine.
However, I can't figure out how to get the emulator and ODKCollect to
connect with ODKAggregate on the local instance. Thank you for your
help.
On another note, I also created an App Engine Instance of
ODKAggregate. I can't figure out how to upload an XForm to this
instance.
Thank you for whatever help you can offer me on both or either of
these 2 issues.
On the android talking to the local instance I think you can configure the
android emulator to point to http://10.0.2.2 that is local machine and to
talk to aggregate you would need goto http://10.0.2.2:8080 (assuming you are
using the app engine local instance).
Also to upload a form on app engine go to the following
http://.appspot.com/upload where you replace
with the id of your app engine instance.
Waylon
help.
instance.
these 2 issues.
Thank you Waylon. That worked. I understand that http://10.0.2.2
directs the emulator to the local machine. Is that standard to use
that IP address to connect to a local machine or is that specific to
the android emulator?
-Eric
> android emulator to point tohttp://10.0.2.2that is local machine and to
> talk to aggregate you would need gotohttp://10.0.2.2:8080(assuming you are
> Waylon
> > help.
> > instance.
> > these 2 issues.
> -Eric
>> Waylon
>> > help.
>> > instance.
>> > these 2 issues.
