We have an aggregate uploaded with four different versions of the
odk-collec forms. We have data uploaded in all the forms in diffrent
amounts; however when we try to visualize/dowmload the csv data files form
the server, the aggregate keeps on freezing (not responding) with the white
page showing. We enabled the billing system and we are paying for the
subscription.
Would you advise what the problem could be; and the solution to it. We are
desperate to have the data downloaded.
Humphreys.
HUMPHREYS KABOTA
DATA MANAGER
INVEST IN KNOWLEDGE (MALAWI)
P.O. BOX 506
ZOMBA
MALAWI.
MOBILE PHONE: +265 999 340648 / +265 881 217403
HOME PHONE: +265 1 952238
SKYPE: humphkabota
What version of Aggregate are you using? If you are using an older
version it could be timing out.
You can also use Briefcase to generate your CSV. Briefcase will
download all the data from Aggregate and do it locally.
Waylon
On Sun, May 13, 2012 at 3:59 AM, Humphreys Kabota wrote:
> Hi,
> We have an aggregate uploaded with four different versions of the odk-collec
> forms. We have data uploaded in all the forms in diffrent amounts; however
> when we try to visualize/dowmload the csv data files form the server, the
> aggregate keeps on freezing (not responding) with the white page showing.
> We enabled the billing system and we are paying for the subscription.
> Thanks,
> Humphreys.
> HUMPHREYS KABOTA
> DATA MANAGER
> P.O. BOX 506
> ZOMBA
> MALAWI.
> SKYPE: humphkabota
I hope you get sorted out Humphreys!
I'm about to start a project in East Africa (3000 respondents) using KoboCollect and 20 Android phones. I do have the latest ODK-Aggregate uploaded and will buy AppEngine credits before going live.
Quick question: When you buy AppEngine credits, do you notice a marked improvement in form submission success rates? Sometimes I have to cancel and re-submit.
DataMax
On Sunday, May 13, 2012 1:59:16 PM UTC+3, Humphreys Kabota wrote:
We have an aggregate uploaded with four different versions of the odk-collec forms. We have data uploaded in all the forms in diffrent amounts; however when we try to visualize/dowmload the csv data files form the server, the aggregate keeps on freezing (not responding) with the white page showing. We enabled the billing system and we are paying for the subscription.
Would you advise what the problem could be; and the solution to it. We are desperate to have the data downloaded.
Humphreys.
HUMPHREYS KABOTA
DATA MANAGER
P.O. BOX 506
ZOMBA
MALAWI.
SKYPE: humphkabota
Humphreys.
HUMPHREYS KABOTA
DATA MANAGER
P.O. BOX 506
ZOMBA
MALAWI.
SKYPE: humphkabota
Humphreys.
HUMPHREYS KABOTA
DATA MANAGER
P.O. BOX 506
ZOMBA
MALAWI.
I have a similar problem. I have Aggregate 1.4.6 installed on my cloud server but still get the error message that a script on the page has stopped responding. Mine actually references line 117 of the ODKAggregate.html file.
Do your filled-in forms have many captured images, audio or video? I'm
trying to gauge whether this is impacting submission success rates when
accessing the servers from the field.
Whether or not you're on a billing plan should not affect the success or
failure of ODK Collect sending completed forms to the server.
Note also that upon first accessing an AppEngine server, it will take a
while for it to start up -- somewhere around 25 seconds, by my measure. So
this would cause the first submission from ODK Collect to take longer than
subsequent ones (if that first submission had to wait while Google "spins
up" the server).
and re-submit.
DataMax
subscription.
Humphreys.
HUMPHREYS KABOTA
DATA MANAGER
P.O. BOX 506
ZOMBA
MALAWI.
SKYPE: humphkabota
subscription.
Humphreys.
HUMPHREYS KABOTA
DATA MANAGER
P.O. BOX 506
ZOMBA
MALAWI.
SKYPE: humphkabota
subscription.
Humphreys.
HUMPHREYS KABOTA
DATA MANAGER
P.O. BOX 506
ZOMBA
MALAWI.
Can you copy-and-paste the actual error or send a screen capture showing it?
And, as always, you should try to upgrade to the latest release at least
once a year.
