Please keep the replies to the list so everyone can benefit. Unless
it's something that needs to be private.
Waylon
Waylon
See the release notes for upgrade steps:
http://code.google.com/p/opendatakit/wiki/AggregateReleaseNotes
Be sure you know what version you have.
http://code.google.com/p/opendatakit/wiki/AggregateReleaseNotes#Determining_Aggregate_1.0_Version
it's something that needs to be private.Waylon
On Mon, May 14, 2012 at 11:43 AM, Humphreys Kabota humphreys.kabota@investinknowledge.org wrote:
Thanks Wylon,
Won't the upgrading affect the already posted data?
HumphreysOn May 14, 2012 8:38 PM, "W. Brunette" wbrunette@gmail.com wrote:
Upgrade to 1.0.6 as there have been bug fixes to increase the size of
the data that can be downloaded.Again if the partners in the US use briefcase to download all the data
they can make a CSV without any timeouts/errors. Briefcase can
systematically extract all data from Aggregate (creates a local copy
on their machine). Briefcase can generate CSV directly from its local
copy.Waylon
On Mon, May 14, 2012 at 11:29 AM, Humphreys Kabota humphreys.kabota@investinknowledge.org wrote:
We are using version 1.0 of the aggregate. We are using the briefcase
aswell; only that our partners in the US also need to have access to the
data
from the aggregate in its raw form.Please assist
Humphreys--
