While exploring ODK Aggregate, we encountered this:
1.Installed Aggregate 0.9 on our Linxux Suse, Local Instance. opened http://localhost:8080 on Suse. looks good and ok.
2.The problem, outside Suse, at a client PC within LAN, we are unable
to open Aggregate on http://IPXXXXX:8080.
3.Seems, we cant send anything to Aggregate Server, unable to access
to the above Aggregate.
I got this to work by doing the following in a terminal:
ipfw add [#] fwd 127.0.0.1,8080 tcp from any to me 80
where [#] is fairly arbitrary, like 5. You can see what numbers are already
used with: ipfw list.
-Carl
On Tue, Dec 21, 2010 at 2:25 PM, razieq wrote:
Dear Waylon, Yaw
Hi there ODK Enthusiasts,
Following the above advice I am now able to use IP address to access
ODK Aggregate. Eg, http://192.168.0.12:8080 from PC where ODK
Aggregate is installed. The command that I used in terminal:
> -Carl
> > Dear Waylon, Yaw
> >http://localhost:8080on Suse. looks good and ok.
> > to open Aggregate onhttp://IPXXXXX:8080.
> > We read and followed the post about http://10.0.2.2:8080@
> >http://groups.google.com/group/opendatakit/browse_thread/thread/c7791...
> > Still no result yet, any advice?
> > tanks
> -Carl
> > Dear Waylon, Yaw
> > tanks
