Its is posible to change the timezone in aggregate on appengine?
because its showing UTC and i preffer to use mi own time zone for
purposes of control.
I have looked but haven't found such a setting.
On Fri, Feb 3, 2012 at 10:56 AM, gap1981 wrote:Its is posible to change the timezone in aggregate on appengine?
Thanks--
Maybe it's a setting of the server. In this case the app engine. But I
don't know.
El feb 3, 2012 3:59 p.m., "Mitch S" escribió:I have looked but haven't found such a setting.
Thanks--
mitchellsundt@gmail.com--
You can't change time zones in GAE -- all you get is UTC.
I suppose we could change Aggregate to allow you to set a timezone,
but that's probably going to be a fair bit of work. Feel free to file
a feature request at http://code.google.com/p/opendatakit/issues/list.
On Fri, Feb 3, 2012 at 11:02, Guillermo Perazzo wrote: > Maybe it's a setting of the server. In this case the app engine. But I don't > know. > > El feb 3, 2012 3:59 p.m., "Mitch S" escribió: > >> I have looked but haven't found such a setting. >> >> Mitch >> >> On Fri, Feb 3, 2012 at 10:56 AM, gap1981 wrote: >>> >>> Its is posible to change the timezone in aggregate on appengine? >>> because its showing UTC and i preffer to use mi own time zone for >>> purposes of control. >>> Thanks >>> >>> -- >>> Post: opendatakit@googlegroups.com >>> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >>> Options: http://groups.google.com/group/opendatakit?hl=en >> >> >> >> >> -- >> Mitch Sundt >> Software Engineer >> University of Washington >> mitchellsundt@gmail.com >> >> -- >> Post: opendatakit@googlegroups.com >> Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=enJust to understand this a little better and talk it through with someone
UTC is a time standard and NOT a time Zone like GMT
The UK in the summer goes to BST (GMT+1) so dates recorded as UTC between Sunday, 11 March
and Sunday, 4 November need to have an hour added to them.
I am working in a time Zone GMT+2 (UTM+2) so the UTM time constant with GMT +2 hours as no light saving time.
However some of the data collected and manually entered is being pushed back a day so some of the date of entry is - 1, I am collecting dates of birth and validity of ID documents so you can see my problem.
I thought the problem was in google sheets but I'm wondering if it could also be in ODK? how can I adjust?
