I'm new to ODK collect, i've been experimenting with the online ODK build
tool to build forms,,, I seem to have a problem with barcodes,,,
as whenever i put a barcode within a group that is a) looped and/or b)
displayed on one screen, the following uncharacteristic things happen
- The fields are NOT displayed on one screen
- After capturing barcode, form input starts at the very beginning of the
form
without barcode field, everything works fine, is this how its supposed to
work ?? is their a work-around ???
Cheers
No, it isn't the way it is supposed to work.
It may be a result of the barcode scanner taking a high-resolution image,
but that is just a guess.
If you can install a tool like Catlog, run ODK Collect to exhibit the
behavior, then, using Catlog, send the log to yourself and create a New
Issue ( http://code.google.com/p/opendatakit/issues/list ) with that log
file as an attachment, that would help us debug this issue.
form
Cheers
And if you can, also attach the form XML to that issue.
> Mitch
>> Hi,
>> 1. The fields are NOT displayed on one screen
>> 2. After capturing barcode, form input starts at the very beginning of the
>> form
>> Cheers
> Mitch Sundt
> Software Engineer
As per request, attached is the xml file,,, and below the log from catlog
with odk as filter
// ---- start log ----
build.board: bravo
build.bootloader: 0.93.0001
build.brand: htc_wwe
build.cpu_abi: armeabi-v7a
build.cpu_abi2: armeabi
build.device: bravo
build.display: FRG83G
build.fingerprint:
htc_wwe/htc_bravo/bravo/bravo:2.2.2/FRG83G/345208.14:user/release-keys
build.hardware: bravo
build.host: ABM041
build.id: FRG83G
build.manufacturer: HTC
build.model: HTC Desire
build.product: htc_bravo
build.radio: unknown
build.tags: release-keys
build.time: 1320404695000
build.type: user
build.user: root
version.codename: REL
version.incremental: 345208.14
version.release: 2.2.2
version.sdk_int: 8
05-01 08:12:22.801 W/PackageManager(93): Not granting permission
android.permission.ACCESS_SURFACE_FLINGER to package
org.odk.collect.android (protectionLevel=2 flags=0xbe44)
05-01 08:20:16.164 I/ActivityManager(93): Starting activity: Intent {
act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER]
flg=0x10200000 cmp=org.odk.collect.android/.activities.SplashScreenActivity
05-01 08:20:16.234 I/ActivityManager(93): Start proc
org.odk.collect.android for activity
org.odk.collect.android/.activities.SplashScreenActivity: pid=705 uid=10083
gids={3003, 1015}
05-01 08:20:58.034 W/PackageManager(93): Not granting permission
05-01 08:21:37.583 I/ActivityManager(93): Starting activity: Intent {
flg=0x10100000 cmp=org.odk.collect.android/.activities.SplashScreenActivity
05-01 08:21:37.674 I/ActivityManager(93): Starting activity: Intent {
cmp=org.odk.collect.android/.activities.MainMenuActivity }
05-01 08:21:38.993 I/ActivityManager(93): Starting activity: Intent {
cmp=org.odk.collect.android/.activities.FormChooserList }
05-01 08:21:41.423 I/ActivityManager(93): Starting activity: Intent {
act=android.intent.action.EDIT
dat=content://org.odk.collect.android.provider.odk.forms/forms/7
cmp=org.odk.collect.android/.activities.FormEntryActivity }
05-01 08:22:15.573 W/ActivityManager(93): Killing ProcessRecord{46716870
705:org.odk.collect.android/10083} (adj 0): unmount media
05-01 08:22:15.593 I/WindowManager(93): WIN DEATH: Window{466ad400
org.odk.collect.android/org.odk.collect.android.activities.MainMenuActivity
paused=false}
05-01 08:22:15.613 I/UsageStats(93): Unexpected resume of com.htc.launcher
while already resumed in org.odk.collect.android
05-01 08:24:09.243 W/PackageManager(93): Not granting permission
05-01 08:24:15.203 I/ActivityManager(93): Starting activity: Intent {
05-01 08:24:15.343 I/ActivityManager(93): Start proc
org.odk.collect.android/.activities.SplashScreenActivity: pid=860 uid=10083
gids={3003, 1015}
05-01 08:24:15.573 I/ActivityManager(93): Starting activity: Intent {
05-01 08:24:16.633 I/ActivityManager(93): Starting activity: Intent {
05-01 08:24:19.473 I/ActivityManager(93): Starting activity: Intent {
dat=content://org.odk.collect.android.provider.odk.forms/forms/6
// ---- end of log ----
eb_ttpl5.xml (3.08 KB)
build
the
form
to
Cheers
Eng. Eric Beda
SACIDS - Regional ICT Specialist
Tel: +255 (0) 787 823 058
Skype: eric_beda
The issue has been filed at
http://code.google.com/p/opendatakit/issues/detail?id=567. Please star
it to follow updates of our progress.
On Mon, Apr 30, 2012 at 10:33 PM, Eric Beda wrote:
> Hi,
> with odk as filter
> build.board: bravo
> build.device: bravo
> build.fingerprint:
> build.host: ABM041
> build.id: FRG83G
> build.type: user
> build.user: root
> version.sdk_int: 8
> android.permission.ACCESS_SURFACE_FLINGER to package org.odk.collect.android
> 05-01 08:20:16.234 I/ActivityManager(93): Start proc org.odk.collect.android
> for activity org.odk.collect.android/.activities.SplashScreenActivity:
> pid=705 uid=10083 gids={3003, 1015}
> paused=false}
> 05-01 08:24:15.343 I/ActivityManager(93): Start proc org.odk.collect.android
> pid=860 uid=10083 gids={3003, 1015}
>> > image,
>> > Mitch
>> >> Hi,
>> >> build
>> >> the
>> >> form
>> >> to
>> >> Cheers
>> > Mitch Sundt
>> > Software Engineer
> Eng. Eric Beda
> Skype: eric_beda
