Hi can some one help me . I have downloaded the ODK briefcase and unzipped
the folder but I don't know the file to
use for installation
Don't unzip it.
Just double-click the ODK Briefcase .jar file, and it should start.
Or, from the command line, you can run
java -jar full-path-to-ODK-Briefcase-file.jar
On Tue, Dec 1, 2015 at 3:41 AM, wrote:Hi can some one help me . I have downloaded the ODK briefcase and unzipped
use for installation--
Hi thanks for the reply I have double click the folder "ODK Briefcase
v1.4.6 Production .jar" but it opens the folder but it doest excute the
folder. My problem is that I have deployed the system, carried out a Survey
with many groups and repeats using Aggregates. when converting data to csv,
i found links for groups or repeats so i am now trying to install Briefcase
in other to pull data from the server. I hav done everything within my
reach but to no avail. Stil need your help
Le mardi 1 décembre 2015 12:41:25 UTC+1, odkm...@gmail.com a écrit : > > Hi can some one help me . I have downloaded the ODK briefcase and unzipped > the folder but I don't know the file to > use for installation >Hi there,
Do you have Java installed? If you are still having problems, try the
suggestions at https://stackoverflow.com/questions/394616/running-jar-file-on-windows.
-- Need ODK consultants? Nafundi provides form design, server setup, in-field training, and software development for ODK. Go to https://nafundi.com to get started.On Sun, Dec 6, 2015 at 5:28 PM, odkmanuel@gmail.com wrote:
Hi thanks for the reply I have double click the folder "ODK Briefcase v1.4.6
Production .jar" but it opens the folder but it doest excute the folder. My
problem is that I have deployed the system, carried out a Survey with many
groups and repeats using Aggregates. when converting data to csv, i found
links for groups or repeats so i am now trying to install Briefcase in other
to pull data from the server. I hav done everything within my reach but to
no avail. Stil need your helpLe mardi 1 décembre 2015 12:41:25 UTC+1, odkm...@gmail.com a écrit :
