When media is updated but form remains the same, sometimes the form gets pushed and sometimes it fails. Usually after a version change it gets pushed with success for a few hours and then it fails again unless the form version is updated. Sometimes even if the form version is updated the push still fails.
2. What app or server are you using and on what device and operating system? Include version numbers. using ODK briefcase v1.16.3. Server is ODK Aggregatev2.0.2 on windows 10
tried pushing forms with the java jar command but it still shows the same behaviour
try pushing a form through briefcase or using the java jar command with csvs or media and then update the csvs and media and push it after about 2 hours
I get the following message when push fails:
form- Start pushing form and submissions
form- Forcing push of form
form- Sending form
form- Error sending form:
form- There are no submissions to send
form - Success with errors
