I have been using ODK briefcase V 1.17.0 to pull data from kc.kobotoolbox.org/myusername without any errors until today. The pull request reaches a certain point and just stops. This failure to pull has started happening after I reached 850+ instances. I have posted on the KoBo Community forum but I was wondering whether this has affected anyone on ODK. Each instance has at least 4 photos and I am wondering whether there is a way to only pull the CSV file.
I have tried checking the Briefcase log and there is no error just the regular warnings. Anyone has an idea of what I should check?
Error log below:
2019-10-24 17:50:00,535 [ForkJoinPool-3-worker-1] ERROR o.o.briefcase.reused.job.JobsRunner - Error running Job
java.util.concurrent.CancellationException: null
at java.util.concurrent.ForkJoinTask.reportException(Unknown Source)
at java.util.concurrent.ForkJoinTask.invoke(Unknown Source)
at java.util.stream.ForEachOps$ForEachOp.evaluateParallel(Unknown Source)
at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateParallel(Unknown Source)
at java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.util.stream.ReferencePipeline.forEach(Unknown Source)
at org.opendatakit.briefcase.pull.aggregate.PullFromAggregate.lambda$pull$10(PullFromAggregate.java:135)
at org.opendatakit.briefcase.util.DatabaseUtils.withDb(DatabaseUtils.java:84)
at org.opendatakit.briefcase.pull.aggregate.PullFromAggregate.lambda$pull$11(PullFromAggregate.java:121)
at org.opendatakit.briefcase.reused.job.Job.lambda$thenAccept$8(Job.java:134)
at org.opendatakit.briefcase.reused.job.JobsRunner.lambda$launchAsync$1(JobsRunner.java:65)
at java.util.concurrent.ForkJoinTask$AdaptedRunnableAction.exec(Unknown Source)
at java.util.concurrent.ForkJoinTask.doExec(Unknown Source)
at java.util.concurrent.ForkJoinPool$WorkQueue.runTask(Unknown Source)
at java.util.concurrent.ForkJoinPool.runWorker(Unknown Source)
at java.util.concurrent.ForkJoinWorkerThread.run(Unknown Source)
