The ODK Briefcase shows "Fail" on Pull Status when pulling data from the
server since yesterday, before that it was always successful. It shows
"Fail" after fetching instances until "....fetching instance 52 ...
retrieving next chunk of instances from server...
FAILED."
I opened the Aggregate and saw an error "Error: Problem persisting data or
accessing data
(roster2@parentAuri(uuid:dd119aa7-447d-4dc0-8262-f4d2d409c5d9) is missing a
(repeat) group instance OR has an extra copy of one)"
The "roster2" is the name of a repeat group in the household roster.
FAILED."
or accessing data (roster2@parentAuri(uuid:dd119aa7-447d-4dc0-8262-f4d2d409c5d9)
is missing a (repeat) group instance OR has an extra copy of one)"
I am also facing the error while pull data through ODK briefcase. Please see the enclosed error snap for more details. Kindly suggest the solution asap.
Thanks. This solved one error (the error in the picture), but I wasn't able
to solve the other error ""Error: Problem persisting data or accessing data
(repeat) group instance OR has an extra copy of one)" because I don't know
the exact query for this error. Any suggestions?
E
On Tuesday, May 5, 2015 at 12:54:15 PM UTC-4, Mitch Sundt wrote:
> This indicates that there was a failure during a submission that led to a
> corrupted submission row. Follow the steps detailed here:
> https://code.google.com/p/opendatakit/wiki/AppEngineTroubleshooting?ts=1430844803&updated=AppEngineTroubleshooting#Reparing_a_Filled-in_Form_Submission
> To repair that submission.
> On Tue, May 5, 2015 at 7:31 AM, Eva Q <ifpr...@gmail.com > wrote:
>> Hi there,
>> FAILED."
>> or accessing data
>> Then afterwards another error shows as below.
>> What could happen here and how to fix this? Hope someone could help on
>> this as soon as possible.
>> Thanks very much!
>> Best,
>> E
>> "ODK Community" group.
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
i'm having the same problem with a failed export from the aggregate server as well as Pulling from Briefcase. The link you've posted is broken, could you please share it with me. Thankyou
Brian
On Tuesday, May 5, 2015 at 7:54:15 PM UTC+3, Mitch Sundt wrote:
> This indicates that there was a failure during a submission that led to a corrupted submission row. Follow the steps detailed here:
> On Tue, May 5, 2015 at 7:31 AM, Eva Q wrote:
> Hi there,
> The ODK Briefcase shows "Fail" on Pull Status when pulling data from the server since yesterday, before that it was always successful. It shows "Fail" after fetching instances until "....fetching instance 52 ...
> FAILED."
> I opened the Aggregate and saw an error "Error: Problem persisting data or accessing data
> What could happen here and how to fix this? Hope someone could help on this as soon as possible.
> Thanks very much!
> Best,
> E
> To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit...@googlegroups.com.
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
asap.
Hope you are fine. If i face tbis problem and intended to hire a developer how much time does it take to fix this problem. I will be very grateful for your information relating problems. In addition how can i hire what is the process thank you for your help.
I will release an ODK Aggregate v1.4.7 later today that will have a log
message that provides the needed information. There are about 4 places
where this less-informative log message was being displayed, and those will
be updated with a log message like I had described in the wiki. The wiki
is also slightly updated to account for some of the variations of the log
messages.
On Tue, May 5, 2015 at 11:30 AM, Eva Q wrote:
Hi Mitch,
able to solve the other error ""Error: Problem persisting data or
because I don't know the exact query for this error. Any suggestions?
E
FAILED."
Brian
FAILED."
I would add that the likelihood of data corruption occurring is tied to the
quantity of form definitions on the server, the size of the individual
submissions, the number of devices simultaneously submitting data, and the
speed of the network.
Except for corruption caused by slow networks, you can reduce the
likelihood of this occurring by increasing the size of your server.
asap.
I don't think you need a software developer. You need someone in IT
who can follow directions and is detail oriented.
The actual fix shouldn't take too long (maybe 30 min?), but doing it
properly requires a data backup and an Aggregate upgrade. Those last
two steps can take up a long time (days) depending on the size of your
data and your connection.
On Sun, Jan 29, 2017 at 12:51 AM, wrote:
> Dears
> To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit+unsubscribe@googlegroups.com.
