I have been using briefcase on a project since May 2020. I have multiple forms on ODK Aggregate. My briefcase has stop working and when I checked the log this is what is logged:
2020-10-19 12:22:59,612 [main] ERROR o.o.briefcase.ui.MainBriefcaseWindow - Failed to launch GUI
java.lang.RuntimeException: Document has no root element!
at org.kxml2.kdom.Document.getRootElement(Unknown Source)
at org.opendatakit.briefcase.export.XmlElement.of(XmlElement.java:68)
at org.opendatakit.briefcase.export.XmlElement.from(XmlElement.java:92)
at org.opendatakit.briefcase.model.form.FileSystemFormMetadataAdapter.isAForm(FileSystemFormMetadataAdapter.java:87)
at java.util.stream.ReferencePipeline$2$1.accept(Unknown Source)
at java.util.stream.ReferencePipeline$3$1.accept(Unknown Source)
at java.util.Iterator.forEachRemaining(Unknown Source)
at java.util.Spliterators$IteratorSpliterator.forEachRemaining(Unknown Source)
at java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(Unknown Source)
at java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.util.stream.ReferencePipeline.collect(Unknown Source)
at org.opendatakit.briefcase.model.form.FileSystemFormMetadataAdapter.syncWithFilesAt(FileSystemFormMetadataAdapter.java:74)
at java.util.Optional.ifPresent(Unknown Source)
at org.opendatakit.briefcase.ui.MainBriefcaseWindow.(MainBriefcaseWindow.java:115)
at org.opendatakit.briefcase.ui.MainBriefcaseWindow.launchGUI(MainBriefcaseWindow.java:94)
at org.opendatakit.briefcase.Launcher.lambda$main$0(Launcher.java:78)
at org.opendatakit.common.cli.Cli.lambda$run$5(Cli.java:136)
at java.lang.Iterable.forEach(Unknown Source)
at org.opendatakit.common.cli.Cli.run(Cli.java:136)
at org.opendatakit.briefcase.Launcher.main(Launcher.java:90)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader.main(JarRsrcLoader.java:58)
2020-10-19 12:23:00,644 [Thread-0] WARN io.sentry.connection.AsyncConnection - Graceful shutdown took too much time, forcing the shutdown.
2020-10-19 12:23:00,646 [Thread-0] WARN io.sentry.connection.AsyncConnection - 0 tasks failed to execute before shutdown.
Please I need solution to be able to meet deadline. Thank you in advance
