Just to give you all a background - I am using ODK briefcase to pull data from several devices and for that I have recreated ODK folder structure where I copied the XML forms in forms directory and all the instances in the instances direcory - exactly how it would be on a phone. Now, this worked great the first time I used it. Now, whatever I do, it is not pulling the data from custom ODK directory to the briefcase - I get a success messgae but it just doesn't pull anything. I checked the physical directories within ODK Briefcase Storage and there is nothing in the instances folder.
Now, to fix this, I have checked my source directory - they are all fine and instances exist. I also tried this by creating a new ODK storage directory. Also tried downloading a new copy of briefcase. Tried on different computers (PC and Mac). Nothing worked.
I will appreciate any help that I can get through this forum. Thanks.
Mandy
Mandy
It does work when pulled from Aggregate server directly over internet. It doesn't work, however, when pulled from the tablet, or ODK folder from SDCard either.
SDCard either.
