Hi everyone,
any help would be greatly appreciated. Many thanks in advance!
We have collected data from around 200 people using a fairly large ODK form on Android tablets. Since we are wanting to stay offline, we have been manually copying the instances from our tablets to the computer to then use ODK Briefcase to pull the data and export it to csv. Both processes, ie. pulling and exporting, seemed to be working smoothly at first, with Briefcase reporting 'SUCCESS' for both. However, when opening the resulting csv in Excel or SPSS, 10 survey results are not displayed properly. Whereas usually each row in the table equals one person and each data input is in its own column, for those 10 cases, we have the data broken up into two or three rows, with columns shifted and sometimes multiple inputs in one column, separated by commas. The data in the xml-files looks completely normal as far as I can tell and also the raw csv-file viewed in the editor shows no abnormalities.
ODK Collect 1.8.1 on tablets (TrekStore Xiron 10.1 pure, Android 5.1.1), ODK Briefcase 1.8.0 on PC (Windows 7 and 10)
I have no idea. It just happens with those 10 people and it doesn't matter if I export just those 10 or them together with other. The data is always displayed in the same wonky way so it seems to be something inherently wrong about those 10 datasets. But I have no idea how those 10 are different from the 190 others that are being displayed without any problems. Both the xml-files as well as the resulting csv looks completely normal as far as I can tell.
I have tried opening the csv with multiple freeware csv to xls converter programs but all ran into the same problem of not displaying those 10 cases correctly. I have pulled and exported each of the problematic cases individually but the results are the same. However, when I open the csv in LibreOffice, everything is displayed correctly, including my 10 problem cases. Now I would love to just use LibreOffice to open everything and call it a day, unfortunately that's not possible as it has a 1024 column limit and our survey has more due to all the empty layout fields that don't take user input but are exported as columns anyways (groupings, notes, etc.).
This is what my Excel table looks like with two examples of unwanted line breaks in row 8 and 30:
Any ideas what could be causing this or how to avoid/fix it?
Or if not, any ideas on how I could restrict my export to include only those aspects of the survey that actually take a user input? If it didn't create columns for every group or note I created to have the survey displayed a certain way in Collect, I'm pretty sure I'd be under the 1024 colum limit and just be able to use LibreOffice to open the data.
