Release highlights
- v1.11.0 - June 19, 2018
- Rework of push and pull UI to allow for configured and not configured states
- On command line, push only uploads the blank form if the form ID does not exist on server
- Rewrite of the export code for improved extensibility and performance
- Instead of form uploader, pull a blank form from computer and push to server
- Detailed release notes: https://github.com/opendatakit/briefcase/releases/tag/v1.11.0
- v1.11.1 - June 27, 2018
- Fix submissions pulled from Collect failing to export
- Recover from moved storage dir failure
- Detailed release notes: https://github.com/opendatakit/briefcase/releases/tag/v1.11.1
- v1.11.2 - June 28, 2018
- Fix issues with storage directory not being created in CLI
- Detailed release notes: https://github.com/opendatakit/briefcase/releases/tag/v1.11.2
- v1.11.3 - August 8, 2018
- Fix issues with exporting in Unicode format
- Detailed release notes: https://github.com/opendatakit/briefcase/releases/tag/v1.11.3
Download release
Report issues
