Release highlights
- v1.12.0 - Sep 12, 2018
- Improved performance of the export operation
- Improvements to the UI, including:
- Less cluttered layout and dialogs on the export tab
- New checkbox to toggle exporting media files on the export tab
- Reload source button on the pull tab
- New CLI flags:
- Enable splitting multiple choice fields when exporting forms
- Enable pulling forms before export
- Enable pulling submissions in parallel
- New errors export output to make it easier to provide support
- Detailed release notes: https://github.com/opendatakit/briefcase/releases/tag/v1.12.0
- v1.12.1 - Sep 28, 2018
- Fix pull before export with sources that don't require credentials
- Fix failing to export all media attachments of encrypted forms with more than one attachment
- Fix repeat group key and export filenames generation
- Detailed release notes: https://github.com/opendatakit/briefcase/releases/tag/v1.12.1
- v1.12.2 - Oct 9, 2018
- Fix ensuring
.csvfile extension is present in exported files - Revert to repeat export filename pattern from v1.10
- Detailed release notes: https://github.com/opendatakit/briefcase/releases/tag/v1.12.2
- Fix ensuring
Download release
Report issues
