ODK Briefcase v1.18.0 is exporting stuck and the progress bar disappears without any error notification
Download ODK Briefcase v1.18.0 jar file and install it. Then I configured the aggregate server, for pulling data from the KOBO form which I had encrypted earlier using RSA. Then I attached the private key in the xls form as described in https://support.kobotoolbox.org/encrypting_forms.html after completion. I pulled the data and tried to export it. While exporting it the progress bar vanishes in a few seconds and the export status is stuck in "Export has started".
I tried to delete the metadata.json file from the bin and tried to execute it again but it didn't work.
log.txt (195.4 KB)
