The "Export to Aggregate" option only works with the newer versions of
Aggregate as code changes were needed in both Aggregate & Build to
enable the exporting. Try upgrading to Aggregate 0.9.4.
Cheers,
Waylon
On Fri, Feb 11, 2011 at 7:46 AM, jeremyg wrote:
> I'm having trouble getting any forms into my ODK aggregate instance
> ( v0.9.2.1 running on GAE )
> I built the form in build.opendatakit.org and have tried both the new
> "Export to Aggregate" option, and the usual XML download and upload.
> In the case of the "Export to Aggregate" I'm asked to authenticate,
> then I eventually get a success message, but no forms appear in
> Aggregate.
> In the case of the XML upload, I'm getting an internal server error.
> Has anyone run into these issues?
> Many thanks for any tips,
> Jeremy
Hi Waylon,
I hadn't realize i wasn't using the current stable release of
Aggregate, thanks for pointing that out.
Export now works.
Cheers
Jeremy
On Feb 11, 8:10 pm, "W. Brunette" wrote:
> Jeremy,
> Cheers,
> > Aggregate.
> > Jeremy
