I have built several forms in ODK Build where I have a group with the
'looped' option selected - xml below.
Form is rendered fine on ODK Collect (ie, I can 'Add New Group' etc) and
uploads fine to Aggregate.
However, when I export the results to csv (ie go to Form List, hit Export,
choose csv), the fields in the looped data are displayed as (what I think
is) a URL... hopefully this renders correctly
Use ODK Briefcase to download the data from ODK Aggregate and generate a
csv file for the top-level group and separate csv files for each repeat
group underneath.
ODK Aggregate's Export to CSV works as designed.
The URL will display the repeat group data for this row.
We punted generating multiple csv files (such as is done by ODK Briefcase)
because Google AppEngine does not allow writing data to a temp directory,
so the resulting zip we would otherwise want to construct becomes very
difficult to do. In the future, we might implement a "flattened" csv file
with all the data, but that has its own design and technical issues.
Briefcase) because Google AppEngine does not allow writing data to a
temp directory, so the resulting zip we would otherwise want to
construct becomes very difficult to do. In the future, we might
implement a "flattened" csv file with all the data, but that has its own
Isn't it possible to stream out a ZIP file with each CSV file in turn,
without writing anything to disk, using JarOutputStream and ZipEntry?
Hi Mitch
I tried using ODK Briefcase to download data from ODK Aggregate but i did not get any CSV files at all. These are the steps i took;
installed ODK briefcase and created the ODK Briefcase storage folder.
I pulled 1195 instances of a form from the ODK aggregate server.
i chose the export directory and clicked the export button
But the directory which i created to hold the exported data, has an empty media folder and an empty file with no extension and 0kb file size.
Have i missed a step? Please assist.
On Wednesday, March 7, 2012 3:25:32 AM UTC+3, Mitch wrote:
> Use ODK Briefcase to download the data from ODK Aggregate and generate a csv file for the top-level group and separate csv files for each repeat group underneath.
> We punted generating multiple csv files (such as is done by ODK Briefcase) because Google AppEngine does not allow writing data to a temp directory, so the resulting zip we would otherwise want to construct becomes very difficult to do. In the future, we might implement a "flattened" csv file with all the data, but that has its own design and technical issues.
> Mitch
> I have built several forms in ODK Build where I have a group with the 'looped' option selected - xml below.
> Form is rendered fine on ODK Collect (ie, I can 'Add New Group' etc) and uploads fine to Aggregate.
> However, when I export the results to csv (ie go to Form List, hit Export, choose csv), the fields in the looped data are displayed as (what I think is) a URL... hopefully this renders correctly
> intro_group:date
> intro_group:id
> intro_group:initials
> R1_readonly
> R1_group
> Tue Mar 06 00:00:00 UTC 2012
> Test
> Cd
> null
> https://kemrishamba.appspot.com/view/formMultipleValue?formId=build_R-ARV-PILL-COUNT_1330909646%5B%40version%3Dnull+and+%40uiVersion%3Dnull%5D%2Fdata%5B%40key%3Duuid%3A3b0461b3-ad60-448b-85ed-1fb41fec5e06%5D%2FR1_group
> This is an issue for every form that I have built with looped content.
> Is there some kind of issue with Aggregate whereby it does not handle repeat data? Or did I do something wrong in the form building?
> Thanks in advance
> Colin
> XML
> R_ARV_PILL_COUNT
> 1
> Colin
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
Yes. However, the Jar writing libraries assume you are writing one file at
a time.
To generate the data, ODK Aggregate would traverse the dataset once,
appending data to multiple file streams (the top-level CSV and a CSV for
each repeat group nested underneath). Then it would need to iterate through
those, appending them onto the JarOutputStream.
The crux of the problem is that ODK Aggregate lacks a facility equivalent
to writing files to a temp directory. The alternative, which we currently
do, is to hold all the data in memory, but that limits the size of the
dataset that can be exported (I estimate somewhere below 6000 records).
Adding repeat group jar support would reduce that size by at least 50%
because of the need to maintain a double copy of the data (once as CSV(s),
once in the constructed JAR) before writing it as complete blobs to the
datastore.
If we had a stream implementation that sent the data into the datastore
(making it act like a temp directory), we could do the repeat groups and
JAR construction, but that is a chunk of work.
On Wed, Mar 7, 2012 at 9:59 AM, Chris Wilson wrote:
Hi Mitch,
technical issues.
To follow up a bit to provide context, Google App Engine is
restrictive on what you can do. When the project started 2 years ago
it was extremely restrictive and it was not possible. Over the course
of the last 2 years they continue to add features that solve some
issues. Separate CSV files while now feasible (previously wasn't even
feasible) would require a bunch of coding to fit into Google App
Engine(GAE) model. The question then just becomes will GAE just
release something in 3 months that makes 1 month of development
working around the nuances to generate multiple CSV at once obsolete,
and the unfortunate answer is probably.
The ODK team has limited resources to add features and this has been
deemed lower priority until more Google App Engine features are added,
especially since ODK Briefcase already gives you the ability to have
what you want. Does it require an extra step? Unfortunately yes, but
our impression from the community as a whole is they would rather have
more features added to ODK this month and wait for Google App Engine
improvement than to spend a bunch of time on code that might become
useless when they are known work arounds.
If this is not the case and the community deems it high enough
priority we can pull development off other features. However, people
have seemed to indicate they want encryption, multi-selects that can
be queried from a database, etc before adding a feature we already
have a work around for.
However this is an open source project so feel free to submit a patch
to fix the problem as we would love to have this solved! Alternatively
you could convince the rest of the community this issue is more
important than other issues so the limited ODK developer resources
will be shifted to fixing this.
Personally, I am not against fixing the problem, but the amount of
resources it will take to fix compared to what other features can be
added (especially since there is an alternative solution), it has been
deemed to be lower priority than other requested features.
Cheers,
Waylon
On Wed, Mar 7, 2012 at 10:51 AM, Mitch S wrote:
> Yes. However, the Jar writing libraries assume you are writing one file at a
> time.
> The crux of the problem is that ODK Aggregate lacks a facility equivalent to
> writing files to a temp directory. The alternative, which we currently do,
> is to hold all the data in memory, but that limits the size of the dataset
> that can be exported (I estimate somewhere below 6000 records). Adding
> repeat group jar support would reduce that size by at least 50% because of
> the need to maintain a double copy of the data (once as CSV(s), once in the
> constructed JAR) before writing it as complete blobs to the datastore.
> (making it act like a temp directory), we could do the repeat groups and JAR
> Mitch
>> Hi Mitch,
>> http://rita.logscluster.org/browser/rita/src/org/wfp/rita/web/controller/ExecutableJarServlet.java
>> Cheers, Chris.
>> Aptivate | http://www.aptivate.org | Phone: +44 1223 760887
>> The Humanitarian Centre, Fenner's, Gresham Road, Cambridge CB1 2ES
>> Aptivate is a not-for-profit company registered in England and Wales
>> with company number 04980791.
> Mitch Sundt
> Software Engineer
> mitchellsundt@gmail.com
We are working on a fairly complex project (20+ forms, between 1 and
15 pages each), which makes it pretty unwieldy to begin with -
additional csvs for each loop just makes it more so. However, after
playing with Briefcase for a while (and generally cutting down on the
loops), I am comfortable saying that the solutions proposed here are
workable. I'm just glad I'm not doing the data analysis I would
be interested in hearing from how other users have approached
wrangling the various csvs into a more usable form (analysis with
SPSS, in this case). Are there responses/threads about this?
This was our first time using ODK, and we have been generally very
happy with most of the coding choices made, and have been very
impressed with the community, level of support, etc. We look forward
to using the ODK suite again in the future.
Colin
> Cheers,
> Waylon
> > time.
> > Mitch
> >> Hi Mitch,
> >>http://rita.logscluster.org/browser/rita/src/org/wfp/rita/web/control...
> >> Cheers, Chris.
> >> Aptivate |http://www.aptivate.org| Phone: +44 1223 760887
> > Mitch Sundt
> > Software Engineer
> > mitchellsu...@gmail.com
Can you confirm that you are seeing the downloaded instances in your "ODK
briefcase storage" directory?
☞§※☼:airplane:
~Neil
On Thu, Jun 27, 2013 at 5:36 AM, wrote:
Hi Mitch
size.
group underneath.
technical issues.
intro_group:date
intro_group:id
R1_readonly
R1_group
Test
Cd
null
I mentioned this in another thread and have put in a feature request for
the issue tracker, but I suggest that the data be exportable in JSON format
as well as CSV. CSV is fine for something that is basically just a bunch
of questions, but isn't very useful for anything that loops, especially if
it is a cross reference of CSV files.
I suggested JSON since it is used quite a bit these days and there are
parsers for the format in almost every language out there. But it is
probably not a supported format for older software packages like SPSS or
Matlab. Actually, having never used something like SPSS, what formats do
work for it?
Sim
I've always imported as CSV, but I know SPSS also takes a bunch of the
MS Office products (Excel and Access for sure, maybe Word?).
Also, Sim, I think JSON export is a great idea, given current levels
of uptake (at least in the areas I'm working in). I'm not sure what
parsers exist that would meet requirements, but I find it way easier
to work with than CSV.
> work for it?
> Sim
> > workable. I'm just glad I'm not doing the data analysis :) I would
> > Thanks
> > Colin
> > > Cheers,
> > > Waylon
> > file at a
> > > > time.
> > for
> > through
> > equivalent to
> > do,
> > dataset
> > because of
> > in the
> > and JAR
> > > > Mitch
> > > >> Hi Mitch,
> > temp
> > becomes
> > "flattened" csv
> > issues.
> > > >> Cheers, Chris.
> > > >> Aptivate |http://www.aptivate.org|Phone: +44 1223 760887
> > > > Mitch Sundt
> > > > Software Engineer
