Good morning.
I had some problems with saving my work on ODK build on Saturday, but
decided maybe the site was in maintenance or something, and moved on to
other catchup work I had planned for the day.
However, today again, it isn't saving correctly for me. I start a new
form, name it, add a few fields and it saves. But things added after that
initial save and NOT getting saved.
HELP. Anyone else seeing this?
Just tested again this morning
Same problem
If I open an existing form, any additions/edits are not saved
No one else ??? gakkk.... I even created a new ODK build user account
and have the same problem.
On Monday, March 13, 2017 at 11:35:47 AM UTC-4, Ruth Little wrote:
> Good morning.
Hi Ruth,
Sorry to hear you are having problems!
Can you please file an issue at
https://github.com/opendatakit/build/issues/new and be detailed about
the steps you take so we can reproduce the problem? Please also
include your operating system and the browser you are using.
> Same problem
> No one else ??? gakkk.... I even created a new ODK build user account and
>> Good morning.
> "ODK Community" group.
Hi Ruth:
I just took a look and couldn't reproduce or locate your problem. I'd love
to ask you a few questions if I may email you directly?
Clint
On Tue, Mar 14, 2017 at 7:16 AM, Yaw Anokwa wrote:
Hi Ruth,
Same problem
and
Good morning.
that
So Dear Little,
I encountered the same problem.
I think you can try a small crooked way I used to sort this out.
My situation: I was working on a form, it had 10 questions and one
particular question had 49 options and I saved the form. Bingo, I had to
start from scratch the next time I logged in.
Solution: I like explaining things in step wise, please bare with me.
*Step 1: *Go to
*Step 3: *Click
*"File"Step 4: *Click -
*"Open form"Step 5: *Select the form you were working on. Say for example
- "saturday's form"*
Step 6: Start working on it. Meaning, complete the form.
Step 7: Click "File" again
Step 8: Click "Save Form As"
Step 9: Rename the file. Say for example "Saturday's form v2"
Step 10: Then log out.
And then log in again to see if the changes you made are present.
Test this by adding only a couple of questions. It worked for me, hope it
works for you as well.* All the best. Let me know if it solved your
problem. *
On Tuesday, March 21, 2017 at 6:01:32 AM UTC+5:30, Clint Tseng wrote:
> Hi Ruth:
> Thanks,
> Clint
>> Hi Ruth,
>> Thanks,
>> Yaw
>> > Same problem
>> account and
>> >> Good morning.
>> that
>> > Post: opend...@googlegroups.com
>> > Unsubscribe: opendatakit...@googlegroups.com
>> Groups
>> an
>> > email to opendatakit...@googlegroups.com.
