I am using ODK Build 0.3.5 offline version and try to upload form to Aggregate but I get "Could not upload the form. Please check your internet connection, and try again." error message.
I am running ODK Aggregate server in using XAMPP (upgraded tomcat server to 8.5.41);
ODK Build and ODK Aggregate Server are running in the same computer;
I use ODK Collect also with Bluestacks and the server is set to "http://10.0.2.2:8080/ODKAggregate/" and it can communicate to ODK Aggregate server (IP: 10.0.2.2 is used as gateway between bluestacks android emulator and computer);
Remove anti-virus in computer;
Turn off Windows all firewalls;
Try http or https protocol in ODK Build;
Try 127.0.0.1 IP in ODK Build;
Try the actual IP (like 192.168.11.125) in ODK Build;
Try to create a new user account in Aggregate Credentials
The form is valid both in ODK Aggregate Server and ODK Collect. If I export the form from ODK Build to XML file and import it to ODK Aggregate Server, the form can work properly in ODK Aggregate Server and also in ODK Collect.
I never connect to ODK Aggregate Server from ODK Build successfully
This one is also ODK Build error message. The different between that one and the above one is the loading icon will know a few seconds in this picture but the above one will tell me the connection problem immediately (less than 0.5 second).
hi @ewezer: sorry to hear that you are having problems. my best guess right now is that Build may not be respecting your :8080 port designation, but i'm not yet sure. i am unfortunately sort of slammed with other work right now so i can't give it a test myself and see if that is indeed the issue.
i hope to get around to this in the next week or so; in the meantime is it possible for you to export to XML and then upload the XML manually to aggregate instead?
My ODK Aggregate server version is v2.0.3. I think it is the latest version already;
I am using the same ODK Aggregate server with bluestacks. In fact, all of them (Aggregate, Bluestack (with ODK collect) are installing in the same computer);
I use "http://127.0.0.1:8080/ODKAggregate" or "http://192.168.11.125:8080/ODKAggregate" (This is my computer IP and I can use the same IP to access Aggregate server through browser) in ODK Build setting, and trying to monitor all log files of Tomcat. Seem there is no any updates in log file after I press "export" button in ODK Build;
