Release highlights
- Check the "cascading" option on any Choose One question to add a cascade onto it, then supply the relevant cascaded option values to create a cascading select.
- Allow copy+paste from spreadsheets into the bulk options editor.
- Add several form properties
- Instance Name lets you set form submission titles from form data.
- Submission URL allows you to submit forms somewhere other than the configured Aggregate server.
- Public Key allows you to use encrypted form submissions.
Read full release notes
Use online release
Download offline release
Report issues
