Release highlights
- v0.4.x - April 13th, 2022
- Form audit log support to log enumerator behavior
- Configurable auto-send and auto-delete in form properties
start_geopointquestion for background location capture and pre-warming GPS -
bearingappearance for decimal question -
likertappearance for select one -
emailmetadata question - short attribute for labels to add concise label shown in ODK Collect's hierarchy view
image,bigImage,audio, andvideoattributes for media questions -
guidanceattribute for hints to add text that can be toggled by enumerators - Form ID and version syntax changed to work better with ODK Central's form versioning
- Improved error handling when no form selected in My Forms
- Improved XLSForm export naming
- Detailed release notes: https://github.com/getodk/build/releases
Use release
- https://build.getodk.org
Report issues
Enormous thanks to @Florian_May (of ruODK fame) for contributing all the improvements in this release.
